I have the 03 as well with the V-Mods, SE filter and the PCIIIR. Originally Steve had indicated on the V-Mod.com website that the PCIIIR was not necessary, however that recomendation was changed at some point to include the PCIIIR and there is a stock map available for the configuration mentioned. There is also a map if you already have the ECM Stage 1 update from HD.
In addtion to the website recomendation update, Steve strongly recommended that I get the PCIIIR (even if it was not from him) because I had the "flat spot" around 4000 RPM, and the V-mod with just the SE filter would have made that "problem" even more noticable. Note, not all V-Rods have this problem.
Bottom line from a user perspective - the bike runs great, sounds great and retains the stock look - and no flat spots in the throttle. Best update that I could have made. The fuel mileage suffers only slightly - well worth it!
My 2c. Good luck!
2003 Silver Annniversary VRSCA
2005 Blk Cherry/ Blk Pearl FLHTCUI
Covering both ends of the spectrum...
