This may not be the same, but I just noticed a oil leak comming from the seam in the side of the case just under the derby cover. It's leaking from where the chrome meets the the gray engine case down on the shifter rod and then on the ground. The bolts are tight so I made a appointment to have the dealer replace the gasket. I can't get in until the 27th. The leak is slow but noticeable. Just what I need. More ammunition for my buddies that ride rice!
'02 V-Rod, V-Mod SE 16ga, SE II Download, SE airfilter, PCR IIIr, syn III oil, topless
