Originally Posted by trustinHD
Is it really necessary to have a valve check at 10.000 miles on a v-rod ? It runs fine, no noises, no ticking etc. I expected that the valves only need to be checked at 50.OOO miles instead. After all, this is a modern engine.
Can I refuse the socalled need check ? I read a lot of vrods checked and none needed to be adjusted.
No. It isn't. The latest tech update that I have seen says the Valve Lash check for 1130cc displacement motors is 15,000 Miles. I believe the Valve Lash check has been moved to 12,000 on the 1250cc bikes.
Your 50K mile plan is a bit generous. I would check valve lash every 30K miles at a bare minimum.
With the overhead valves, the valve lash should get SMALLER and require thinner shims as the valves seat.
If it ain't water kewled, you're just blowing hot air.
V-Rod Editor, American Iron Magazine
