Do your running lights work? Does your brake light work?
If your running lights work, and your brake light does not, then you are getting no power to the accessory circuit. The place to check is the ignition switch. It may need to be cleaned and fresh dielectric grease put in. It's really not a COMMON issue, but it does occur.
There is a realtively easy way to bypass the switch to check, and you can PM me if you want to know that tidbit of info.
RJ
If it ain't water kewled, you're just blowing hot air.
V-Rod Editor, American Iron Magazine
