Hey Anybody Have Info On Longer V Rod Fork Tubes, I'm Working On A Project With A V Rod Front End 2007 49 Mm ,stock Legnth Is 30'' ,i Need It To Be 32'' ... Switching The Tubes With A Dyna Set ,also 49 Mm, Is A Problem I'm Finding Out Because The Damper And Oil Stop Is Larger On Dyna Tubes Then V Rod...i Need To Use The Dual Disc Lower Sliders Because I'm Useing V Rod Cast Wheels And Factory Brembo Brakes And Rotors Which Will Not Fit Any Other Harley...any Input Or Direction To Go Would Be Greatly Appreciated
