aka matt: The dyno sheet for the Stage I 110" kit shows the SE 255 cams, etc. and new heads. It shows 95 ft lbs torque dropping quickly after 4,000 rpm and a max of 80hp. I mistook the Stage I 103 graph for a stage II graph, but the dyno sheet for the 110, with the SE 255 cams AND new heads doesn't show much change from the stage I 103--very modest hp gain and a torque curve that drops fast after 4K rpm. There is no dyno sheet, but the data from the others points towards numbers that would put torque below 95 ft lbs, and hp below 80, if it is assumed that the heads included with the 110 improve torque and hp.
CMA, Crossties Chapter (GA)
IBA 26580
2004 FLHTPX
