Originally Posted by DLeppik
Han anybody tried installing the Aux running light/brake/turn signal conversion on a 2007 part # 69461-06. My friend installed this on his 2007 Ultra and there was problems with the operation. I have the brake light only turn signal conversion on my 2006 Ultra which has worked fine but when I put it on his 07,again there was problems with the operation. I tried his aux/run/brake/turn on my 2006 and it works fine?
I was wondering if something is different on the 07 to cause this?
Doug
Doug;
You don't say what your problem is, you just say theres a problem.
I learned about the lights on my 07 Ultra the hard way, the turn signals
and 4 ways run through the security computer, the computer controls
the left and right signals and the 4 ways.
I put a trailer hitch on my 07 Ultra and hooked up my trailer lights, they
worked fine. I took it for a short ride with the trailer, when I got home
and unhooked the trailer is when the problems started.
The problem was now the computer was use to the extra load the trailer
had put on it and it adjusted for that, now it could not go back so my
turn signals would flash normal for 4 flashs and then go into a fast strobe
light like flash and stay that way.
My Harley dealer did not know how to fix this, so being a motorcycle
mechanic for over 40 years I decided to take a whack at it. By hooking
an 1157 bulb with both elements hooked together I pluged it into the
trailer plug trying to fool the computer into thinking I hooked the trailer
back up to it. With this they flashed normal again. Some how in my trying
different combo's of flash's I found a code that put the computer back
into the stock mode.
My problem is I don't know what the code ended up being, so now I need
to hook up the trailer again to knock it out of whack again so I can try to
find the code I triped on the first time. I don't know when I'll get to that
as I'm a little busy in my shop right now + I/we wife and I ride alot, we
rode over 50,000 miles in 2005 and we are over 60,000 miles so far for
2006. My Ultra which my wife gave me for my birthday is about 6 weeks
old now and it has over 9,000 miles on it in those 6 weeks. So between
my shop and my/our riding it might be a while before I get back to trying
to figure out the code I triped on.. LOL"
Let me know if you are having the same problem? Because if you are that
would make me look into it quicker to help you out, other wise it is on my
back burner for now.
My Shop/Cell number is 704-236-2885 if you want to talk about your
problem my friend..
Chuck...
