Note that the head shake problem only exists at slow speed if the trike is done right---i.e. below 25 or so. Also, he might want to check the head bearings to make sure they are tight---Goldwings are none for them being off and causing shake (I had a Goldwing that would do it at 60 plus until adjsted). there is also a steering damper than can help.
Once you ride for a while, you do not notice/fight the little shake there is a good setup. The raked trees will be easier to steer however, and are normally recommended on Goldwings. On big Harleys,they are normaly left to the rider
