Squeaky Muffler Bracket on 2000 Ultra - Fix? : V-Twin Forum: Harley Davidson Forums
Old 04-08-2006, 01:02 PM   #1 (permalink)
Registered User
ezrider wants to know Dino or Syn?
The left side rubber bushing that holds the muffler on at the rear top is squeaking like crazy. Do I I need to lubricate the bushing with something like car bel dressing, replace it or what?
Thank you.
ezrider is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 01:28 PM   #2 (permalink)
2008 Ultra
Almost There's Avatar
Almost There wants to know Dino or Syn?
I had the same problem on my Ultra a few years back and I sprayed WD-40 on the rubber bushings and the chirping sound went away. It happened mostly after riding in the rain or after a good soaking at the bike wash.
Every once in a while that chirping sound would come back and I'd spay it in again. Hasn't done it a few years though ...
Cheers
_________________________________
The road ... it has always been the place to find the answers ... or ignore the problems.
Almost There is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 02:00 PM   #3 (permalink)
Registered User
No WD-40 on hand so used spray silcone, seems to work fine.
Thanks!
Old 04-08-2006, 02:29 PM   #4 (permalink)
0043--Licensed to Doof!
Geezer-Glide's Avatar
Geezer-Glide wants to know Dino or Syn?
That works, or if you can find a dry lube. That way theres no dirt attraction.
Seat, frame, stroker motor, paint, some chrome, two wheels, tires, road grime and a couple of old dead bugs. Fun meter.......PEGGED!!!
I Doof, therefore I am.
D.F.F.D
Geezer-Glide is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 02:32 PM   #5 (permalink)
aztriker wants to know Dino or Syn?
I agree with what's said and done but would also like to mention that those things become hard from the constant heat and will start squeeking. Might consider replacing them. I see yours is a 2000 but don't know what kind of mileage you have so don't know how much heat abuse they've received. Just a thought.
aztriker is offline   Reply With Quote Quick reply to this message
Old 04-08-2006, 02:35 PM   #6 (permalink)
Registered User
I will probaly replace them, doesn't look like a big deal to do?
Old 04-08-2006, 03:10 PM   #7 (permalink)
Harris
Guest
Posts: n/a
It's simple to replace, and they're only about $2.50. If the problem is solved with lube, then good enough. Otherwise I just replace.
Harris
Old 04-09-2006, 09:25 AM   #8 (permalink)
72FX/04Ultra
fauskar wants to know Dino or Syn?
Here's what I do.
Loosen the muffler clamp and support bracket screws. With the bike upright, I place a bubble level on the bracket and rotate the muffler until it levels. Then tighten the muffler clamps (while holding the muffler in position) and finally the support bracket screws.
The first thing you'll notice when doing this; the muffler has the potential to easily be +/- 15 degrees out of level. If it's rotated, you're forcing and cocking the bracket agianst the rubber bushing/isolator. This limits the directions that the bracket can move.
When the muffler is level, the support bracket is relatively loose in the bushing normally. It rests on the bottom of the bushing and the muffler is free to move left, right and up.
When I have done it this way, I haven't had any problems with noise.
Klaatu barada nikto
fauskar is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 10:30 AM   #9 (permalink)
bagga's Avatar
bagga wants to know Dino or Syn?
this is how i did it. get a can of beer or soda, drink it,cut the can up to make some shims, put them between the rubber and the bracket. you may need to make more than 1 shim to get the shake out.
bagga is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 08:19 PM   #10 (permalink)
47,503 and adding
2001FLHT wants to know Dino or Syn?
I quieted mine by turning the clamp through the bushing upside down. Goes in tight and quiet. No squeaky irritating noise that I cannot explain. Kinda like when the brakes squeak.
Larry
2001FLHT is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 09:06 PM   #11 (permalink)
Seasoned Prime Member
RoadKingCurley wants to know Dino or Syn?
I just took clear silicone caulk and squirted some between the rubber and the mount. Let it cure, then ride! Two years and no squeek.
RoadKingCurley is offline   Reply With Quote Quick reply to this message
Old 04-09-2006, 11:47 PM   #12 (permalink)
Hoss wants to know Dino or Syn?
That's what that noise Ive been hearing is...............THANKS
been buggin me for a couple weeks now.
I want to die in my sleep, like my Grandfather.Not screaming and yelling like the passengers in his car!
Hoss is offline   Reply With Quote Quick reply to this message
Old 04-10-2006, 08:01 AM   #13 (permalink)
Registered User
Went for a 150 mile ride yesterday and so far the silicone spray is working.
