Page 8-75 in the 2001 Touring service manual has steps to remove the speedo from a FLHR/C.
Obviously one if the steps is to unbolt the instrument console from the gas tank. That is achieved by removing the acorn nut and the philips screw.
Once the instrument console is unbolted from the gas tank, flip it over and you will see what electrical connectors need to be disconnected.
If my memory is correct, I believe there are 3 connectors..speedo, indicator lights, and ignition switch.
In addition, I believe you have to remove the trip odometer reset switch from the console.
Thats basically it, not difficult to do.
The speedo will come off with the console. If you need to remove it from the console, the lock ring on the back side of the speedo needs to be removed, and then the speedo can be lifted out from the top side of the console.
Just be sure to note routing of cables and wires, so that when you reinstall them you do not pinch them when installing the console back on the gas tank.
There are some flexible clips that help hold the cables in place..be sure to use them.
