Replacing Speakers on Road Glide : V-Twin Forum: Harley Davidson Forums
Old 03-25-2005, 06:50 PM   #1 (permalink)
rgterry wants to know Dino or Syn?
I will be replacing stock speakers on my 05 RG with some Hog Tunes. Has anyone done this themselves and how complicated is it to remove the faring? Also, is best to remove inner or outer faring to replace speakers. Any and all tips, suggestions or cautions are welcome.
Keep it on the road
RGTerry
05 Road Glide
King Tour Pak
95 BB2
Mustang Seat
Magellan GPS
RGTerry
Keep it on the road
www.ridingtherim.com
rgterry is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 07:20 PM   #2 (permalink)
lowbar wants to know Dino or Syn?
It's a piece of cake. You just need to pull off the outer fairing. Not hard but I would suggest getting the service manual. Chicago Harley has a 20% off sale until the end of the month. http://www.chicagoharley.com/
lowbar
If you think that there is good in everybody, you haven't met everybody.
lowbar is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 09:19 PM   #3 (permalink)
d9ballfarm wants to know Dino or Syn?
its fairly easy .thereis 6 allen head screws on the inside fairing remove those. remove the windshied,take off the front 2 turn signals. piece of advice put a protective cover on the front fender to keep the outer fairing from hitting it. after all is loose u want to grab the outer fairing and lift it straight up. its held on by 2 hooks behind the headlights. disconect the headlights unplug them. remove the speakers and replace. to reassemble take headlight completely out and place the outer fairing back on with the headlights out u can see where it hooks on .put headlights back on and then reverse the steps. the first time is allittle intimidating but after the first time its a breeze.probably had mine off 6 times already. never am satisfied . good luck
d9ballfarm is offline   Reply With Quote Quick reply to this message
Old 03-28-2005, 01:41 AM   #4 (permalink)
Av8r3400's Avatar
Av8r3400 wants to know Dino or Syn?
Important safety tip: On my RG, the screws varied in length and if you put the wrong screw in the wrong hole, it will crack the finish.
Av8r2230
Mine: 2000 FLT Hers: 2002 FLHRI
Av8r3400 is offline   Reply With Quote Quick reply to this message
Old 03-28-2005, 08:02 PM   #5 (permalink)
BigTinVA wants to know Dino or Syn?
Who sells the Hog Tunes speakers?
BigTinVA is offline   Reply With Quote Quick reply to this message
Old 03-29-2005, 09:38 AM   #6 (permalink)
tyancey00's Avatar
tyancey00 wants to know Dino or Syn?
http://www.hogtunes.com/speakers.htm
They also have a discount link, I don't have it saved.
tyancey00 is offline   Reply With Quote Quick reply to this message
