The earlier units work well with the flat silicone printed gaskets.
The later ones work good with the molded silicone seal ring. Just don't pull it out of the grove. For some reason, some of them refuse to sit back down in the groove after being pulled out.
I got a gasket set from the dealer. Had derby cover gasket (the flat black full cover with silicone seal), primary inspection cover gasket, drain plug o-rings all included.
Mine came original with 'quad' gasket which was rubber o-ring that fit into groove. As time went on that became obsolete and dealers handed me the black flat solid gasket with silicone seal. Over the years both worked fine for me - and I re-used them through multiple oil changes. Just took the time to clean them up (and seating surfaces), inspect and reassemble.
Related Threads
V-Twin Forum
2.7M posts
146K members
Since 2001
