Having problems with 03 Road Glide radio. Right speaker works intermittently. Trying to decide on repair or replacement. Been hearing about aftermarket radios that are plug and play to all factory controls. Suggestions?
make sure its the radio , I had the same issue turned out to be a bad speaker, the ground was bad causing it to drop at times, replaced with a set of aftermarket and all is good.
If it is the head unit there are alot of options for replacement you can use any Radio Sound head unit from 98-06 or Radio sound can repair yours for a small fee. I just picked up a good unit from an 04 with the cd player that was a direct fit for my 01 if your not in a real hurry watch Ebay for a take off .
I have also heard that the newer HK units will fit but I do not have first hand knowledge of this .
