Tour Pack Lights for Electra Classic : V-Twin Forum: Harley Davidson Forums
Old 11-09-2003, 02:16 PM   #1 (permalink)
Ridin' with the King
frankencat's Avatar
frankencat wants to know Dino or Syn?
Anybody know of a nice aftermarket solution for Tour Pack rear lights? Don't really like the big ol Ultra lights and would prefer something like a nice LED setup. I know about the HD Spoiler and am considering that but is there anything else around? For the $$ it would seem to me that there would be other options.
Higher Ground Band
Rockin' for Jesus!
frankencat is offline   Reply With Quote Quick reply to this message
Old 11-10-2003, 05:36 AM   #2 (permalink)
Kampnnut's Avatar
Kampnnut wants to know Dino or Syn?
I added a pair of LED light just below the lid on the tour pack. They are about 3 inches wide and spaced evenly from center. I spread them as far out as the radio antenna would allow. They are used as running light, brake lights, and turn signal. I tided them into the HD module that allows the turn signal lights to act as brake lights too. That way I did not have to cut into any factory wiring. I ran a wire from the module under the seat up through the normal wiring hole in the tour pack. Then I removed the metal plate at the bottom of the tour pack to get to the wiring. Not a very difficult at all. What I hated the most was drilling holes in the tour pack. There is a slight curve to the tour pack, but the lights were not very wide. The curve of the tour pack was not a problem. I feel a little safer with the extra light especially sense the lights are higher up.
2009 Ultra Classic
Kampnnut is offline   Reply With Quote Quick reply to this message
Old 11-11-2003, 09:01 PM   #3 (permalink)
frankencat's Avatar
Thanks Kampnnut. Do you have any pics?
Higher Ground Band
Rockin' for Jesus!
Old 11-13-2003, 04:15 PM   #4 (permalink)
Bikermedic wants to know Dino or Syn?
Hey Kampnnut,,,, I was thinking of adding the big ol ugly lights to my classic. Can you post pictures on this forum? If not I would appreciate you sending pictrues. Thanks
Bikermedic is offline   Reply With Quote Quick reply to this message
Old 11-14-2003, 05:27 AM   #5 (permalink)
Kampnnut's Avatar
I'll try to take a couple pictures this weekend it this ole 53 yr old brain can remember.
2009 Ultra Classic
Old 11-16-2003, 07:32 AM   #6 (permalink)
Kampnnut's Avatar
The picture does not do the lights justice.
2009 Ultra Classic
Old 11-16-2003, 07:52 AM   #7 (permalink)
Mister Breeze wants to know Dino or Syn?
It would be hard to outshine the wax job you have on that baby! Talk about a mirror finish. By the way I like the lights too.
...I keep roll'n down the road...
Mister Breeze
Mister Breeze is offline   Reply With Quote Quick reply to this message
Old 11-16-2003, 08:46 AM   #8 (permalink)
frankencat's Avatar
Nice! Thanks for the pic
That is exactly what I was thinking of except I want to put a 6" in the middle for run/brake and two 3"rs like you have on either side for run/turn. How do you have your wired?
Higher Ground Band
Rockin' for Jesus!
Old 11-16-2003, 08:36 PM   #9 (permalink)
frankencat's Avatar
Check these out...http://www.radiantz.com/1562.htm
Pretty cool but not sure how well they hold up and they are a bit $$.
Higher Ground Band
Rockin' for Jesus!
Old 11-18-2003, 07:56 AM   #10 (permalink)
srb8267 wants to know Dino or Syn?
Here's another option. You can buy the light for the H-D spoiler without the spoiler. Mount the light to the bottom trailing edge of the tour pack. I attached the light to a piece of angle aluminum and then mounted the angle aluminum to the two existing rear bolts that at the bottom/rear of the tour pack. Didn't have to drill holes in the tour pack. The light tucked up under the tour pack so you hardly notice it until it comes on. Another good point about this light is I didn't have to splice into light wires. It comes with a connector to fit the accessory plug located in front of the battery (02' FLHTC) which operates the tail and stop lights of the new LED light bar.
srb8267 is offline   Reply With Quote Quick reply to this message
Old 11-19-2003, 10:46 AM   #11 (permalink)
Revonacruiser wants to know Dino or Syn?
I installed LEDs under the back edge of the tour pack; check out options at http://www.cyclegadgets.com.
Revonacruiser is offline   Reply With Quote Quick reply to this message
Old 11-20-2003, 10:47 AM   #12 (permalink)
frankencat's Avatar
Thanks srb8267. You wouldn;t happen to have a part numebr for that bad jammie would ya? Can't seem to locate just the light in the HD catalog. Thanks
Higher Ground Band
Rockin' for Jesus!
Old 11-20-2003, 07:29 PM   #13 (permalink)
frankencat, there's the info:
TOUR PACK SPOILER LE
part # 68160-99
price $49.95 (July 2002)
I'ld post a picture but I can't figure out how.
Old 11-20-2003, 07:49 PM   #14 (permalink)
frankencat's Avatar
Kewl. Thanks
Higher Ground Band
Rockin' for Jesus!
Old 11-21-2003, 03:49 AM   #15 (permalink)
srb8267:
Sure would like a look at your setup if you can fiqure out how to post a pic. Sounds great.
Mister Breeze
