evo will not crank : V-Twin Forum: Harley Davidson Forums
Old 03-19-2013, 09:49 PM   #1 (permalink)
JDwiz wants to know Dino or Syn?
evo will not crank
Ive got a 1990 FLHTC. 105000 mi. At the end of last season, lifter roller bearings went thru oil pump. Tore down, cleaned, replaced pump, cam, lifters, pushrods, cyl & pistons, heads. Running SS carb.Screamin Eagle ignition. Motor cranks over fine without plugs, great oil pressure. Put plugs in, nothing. Got new battery, nothing.New starter, same. Jumped off truck, cranks real slow. What am I missing? Riding season almost here need help.
The heads I put on were HD reman heads thet had interts put in them where the breathers would go on late Evos. Could these heads be causing my problem?
Last edited by JDwiz; 03-19-2013 at 10:03 PM. Reason: forgot to add info about heads
JDwiz is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 12:27 AM   #2 (permalink)
webco2 wants to know Dino or Syn?
Sounds like you are losing voltage under load. Did you check to make sure both ends of all high amperage cables are good and that they are tightend up on clean connections ? I've found cable ends pulled loose before .
webco2 is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 07:45 AM   #3 (permalink)
bob01flhtc wants to know Dino or Syn?
Start with the simple stuff. ground and battery connections. check voltage while cranking. your head and piston combination could be giving you too much compression. jumping a bike with a car or truck can damage voltage regulator.
bob01flhtc is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 05:43 PM   #4 (permalink)
Mike02's Avatar
Mike02 wants to know where he is and how he got here
Compression
I agree here.. check the simple stuff first... if that's OK time to think about compression. Allthough I doubt that is the problem...I have compression releases on my 02 RK b/c of high compression but the starter will turn the engine over even if I don't engage them.
Mike02 is offline   Reply With Quote Quick reply to this message
