01-16-2013, 09:11 AM
2006 Road King
Hi, got a friend who bought a 2006 roadking and says it has a 103 in it,was stock engine in 2006 88in or 96 in ,if was 88in be hard to get 103,driving him nuts,any info would be great ,thanks
2004 heritage classic/i
104 build
cp flat top pistons
Andrews chain conversion
OFlarry cnc heads(80cc)
Fatcat 2:1
S&S 585 easy start cam
GMR pushrods
tuned by Razorback performance & Dyno =BVBOB
01-16-2013, 09:36 AM
It could have the SE 103 build in it very easily.
Stock engine in 2006 was an 88"
01-16-2013, 09:43 AM
so does it have a 4 inch crank then or 4/38 then
104 build
cp flat top pistons
Fatcat 2:1
GMR pushrods
01-16-2013, 09:48 AM
01-16-2013, 12:15 PM
that helped alot Pumba11,didnt know that was a option in 2006,thanks again
104 build
cp flat top pistons
Fatcat 2:1
GMR pushrods
01-16-2013, 02:36 PM
Axe Man
That bike came stock with a 4 inch stroke crank, most of the 103 SE setups installed also had the SE heads and will have the badges. More likely he has a 95
2007 Ultra
114 CI
SE cases
Woods 8 cams
Reworked 110 heads by nw guy
Thayer 3 stage oil pump
V&H true duals trapp mufflers
103.. on the workbench
1982 FXRS
Scratched paint
Rotten tires
Bad brakes
Sticky clutch
Still runs like a champ
01-16-2013, 04:48 PM
Ironbutt
Stock 2006 engines (non CVO) were 88 ci. It's possible the engine could have been converted to a 103 after delivery. Difficult to tell what it is without opening up the engine. I wish sellers would make more of an effort to pass on documentation of upgrades.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
01-16-2013, 05:20 PM
If it was a 103, I'd assume the previous owner would point that out and show proof.
It would make it easier for a sale.
01-16-2013, 05:41 PM
well i asked he said it was 103,its got tman stage 3 heads and 590 cam tman,so i dont know what to say now ,he says it says 103 on title ,so would the tman heads cross out the badges
104 build
cp flat top pistons
Fatcat 2:1
GMR pushrods
01-16-2013, 05:53 PM
what about vin number isnt there a stamp on engine as well?
104 build
cp flat top pistons
Fatcat 2:1
GMR pushrods
01-16-2013, 07:40 PM
I agree....
He can say all he wants to say....that bike came stock with an 88" engine.The burden of proof is on him unless u want to believe what he says. I seriously doubt it says 103 on title. To be a 103 it needs a crank and pistons/barrels. Does it like like the complete engine has been out and the cases split? If he says T-Man did work on it make him produce a receipt. Last option is a dyno run, see what it puts out. There is no real way to check w/o taking stuff apart.
2000 Road King on Mulholland approaching the Rock Store. Bike now has Contrast Cut PM Judge wheels and a plethora of new goodies. New pic to follow.
01-16-2013, 08:15 PM
ya,im starting to believe some one not telling the truth,sorry
104 build
cp flat top pistons
Fatcat 2:1
GMR pushrods
01-16-2013, 09:20 PM
Barney Fife - Fake Biker
Nobody tells the truth about a bike (or car) they are trying to sell.
G Man
'97 FLHPI
80c.i. - EV27 cam - stock pistons - stock heads
SE a/c - Rinehart True Duals - Barnett performance clutch
MM EFI - hi flow injectors - PCIII USB
Tru-Trak stabilizer - customized Corbin seats - beach bars
chrome crap - detachable stuff
01-17-2013, 08:26 AM
so correct me if i am wrong,to go from 88 to 103,can that be done by taking the 88 apart split cases ,put 4 3/8 fly wheel ,would you bore the case for cylinders and then 103 is possible?
104 build
cp flat top pistons
Fatcat 2:1
GMR pushrods
01-17-2013, 08:59 AM
Location: The Burning Sands of NV; formerly the Pines of NJ
Re: 2006 roadking
There is no need to bore cases. 88" goes to 103" by boring stock cylinders to 3.875" and replacing 4" stroke flywheels with 4-3/8" stroke wheels. This was available as a Screamin Eagle "kit" for 88" twin cams. So yes, engine comes out, cases are split (but not bored), crank replaced & cylinders bored (or replaced) with new 3.875" pistons fitted.
Sent from my VS840 4G using Motorcycle.com Free App
Eric
'02 Road King
95" Science Project
| Sponsored Links |
