the only change in the past year was the air intake i went from the heavy breather to ventilator when i added glove boxes. then i had oil leaking out of filter, so like a lot of other riders i added tubes to direct the dripping oil into the throttle body more. could the oil dripping at the higher rpms cause the bike to go into limp mode. as long as i don't hit 5300 or a little higher rpms the bike runs great, great response, and quick. normal ridding 2600 to 3400 rpms and even getting on it the rpms are usually under 5000. just a little puzzled since i never had the bike go into limp mode before. and thanks for the responses
