12-17-2012, 12:06 PM
Sluggish engine
Its hard to explain whats going on but my bike is real sluggish. the plugs, wires, battery have been changed but that was a few months ago. compared to the bikes i ride with my bike is a dog. i have a 2004 electraglide standard efi. the mufflers are aftermarket ovals not sure they are made by, other than that the bike is stock. it seems like i lost a lot of power. what could cause some things like this? thanks
12-17-2012, 01:12 PM
Make sure your air cleaner is clean and isn't obstructing air flow.
Check throttle cable adjustment, make sure you're getting full throttle.
If neither of those solve the problem have the mapping checked.
12-17-2012, 01:40 PM
will do thanks.
12-17-2012, 02:47 PM
Unless you recently changed components, and if it ran well with the current components and EFI map, it's unlikely to be the map itself. Could be a dirty air cleaner or a bad sensor or throttle cable issue. Otherwise, do a compression check.
2008 Road Glide
Phoenix Customs Bagger Brace
Glide Pro
Clearview windshield
107
CP flat tops
R&R Stage 3 heads, .030 gasket, 82cc chambers
Trued, welded, and balanced crank by Hyperformance
TMan 590 cams
SE AC
HPI 54mm TB
Supermeg with open cap and 15 discs
TTS tune by BVBob
2003 Indian Scout Deluxe
Aspen White (got it for my wife)
S&S "SuperStock" 88"
12" apes
Scary fast!
12-17-2012, 03:16 PM
Add the fuel filter to the things on the check list.
Make sure you don't have a caliper dragging.
"All mankind is divided into three classes: those that are immovable, those that are movable, and those that move."
12-17-2012, 05:36 PM
Bad gas. Compression check. Excess oil in crank case. New plugs/wires bad? Fuel vent plugged?
2012 RGU Vivid Black, SE 254e Cams, SE intake, SE race tuner, Rinehart TD 4'' Exhaust and Road Zepplin Seat. Added Tour Pack lighting and signal kit. A lot of chrome.
12-17-2012, 06:04 PM
thanks folks i will check all of that and if that doestwork ill take it in fora checkup.
12-17-2012, 06:34 PM
What are you comparing your bike with? All Harley's are Dogs except the V-Rod.
Regards,
John
2002 Road King Classic w. 103" Stroker
2007 VRSCX 0461 / 1400
2003 VRSCA (Gone but not forgotten)
12-17-2012, 11:13 PM
Are you running the same brand of gas all the time? I know a couple of months ago here in NC that the " May contain 10% ethenol " stickers started showing up everywhere. I don't know how Va. is blending their fuel but that could be a possibilty especially if you're running 87 octane gas. I always run premium fuel, usually Shell, & haven't noticed any difference with mine. Shell was also included with the added sticker, right now I don't know of any gas here in NC that is not labeled as "may contain", so now it's a real crap shoot as to knowing what you're burning.
12-18-2012, 09:56 AM
im compairing other eglides with the same engine and all stock. i use high test and i get it from different places all the time.
12-18-2012, 10:02 AM
Gaso flow, replace the filter and do check the fuel lines too.
Ride with an attitude
12-18-2012, 06:25 PM
With those after market mufflers it is possible the bike needs a good tune. Changing either air intake or the exhaust system alters the A/F ratio consequently it should be checked to see if a tune is in order.
Regards,
John
12-18-2012, 07:38 PM
Could be fuel or after market pipes need more air or map adjustment
Sent from my iPhone using Motorcycle.com Free App
12-18-2012, 08:20 PM
sumping oil into the crankcase?
or pin hole in the fuel line inside the tank. ?
07 ULTRA
SE 120Rxtra
12-18-2012, 09:10 PM
Check the fuel filter.
| Sponsored Links |
