Streetglide wheel to an 01 RK : V-Twin Forum: Harley Davidson Forums
Old 12-10-2012, 07:01 AM   #1 (permalink)
Steelernation is on a distinguished road
Will a 09 and newer front wheel bolt up to an 01 RK? Like the simple look and low maintenance of this style wheel.
Steelernation is offline   Reply With Quote
Old 12-10-2012, 02:57 PM   #2 (permalink)
Slick03 H-D's Avatar
Slick03 H-D is on a distinguished road
I don't think so, if I'm not mistaken its a different size axle/bearing...I may be wrong, but look at the wheels in the new parts/acc catalog and see where the break is.
03 100th anniv silver & black bagger/SOLD IT/MISS IT
2013 110th anniv dark bronze metallic & black bagger.
Andrews 57h cams/.020 off the heads/SE adj pushrods
Drago's Dragula 2 into 1 pipe
H-D Ventilator air cleaner.
TTS tuner/dyno by Doc/98hp & 107tq
CVO adjustable rear shocks
Leather C&C seat
Freedom 8" dark smoked windshield
Streamliner boards/pegs
Nostalgic bag rails and as much chrome as I can find
plus more stuff to come much to my wife's dismay.
Slick03 H-D is offline   Reply With Quote
Old 12-11-2012, 11:41 AM   #3 (permalink)
TexasBowhunter is on a distinguished road
I understand it will
You will need the axel replaced to the 08 and later though
different size bearing
I was kinda wondering though if the bearings were changed over to your dia. if this would be a simple swap where you would not need a axel...
paul
TexasBowhunter is offline   Reply With Quote
Old 12-14-2012, 06:42 AM   #4 (permalink)
Was told that the bearing would need to be swapped but it wouldn't be an issue. Kinda surprised with some of the prices I've encountered for the take off wheel. 100+. I'm probably a bit cheap I guess. Decided to stay with the stock set up has always served me fine in the past. Now for new tires.
Old 12-14-2012, 07:04 AM   #5 (permalink)
Hunter1 is on a distinguished road
I put a `12 SG front wheel on my 05 RK. My stock wheel had 1' bearings so I ordered a 25mm axle and spacers to fit the SG wheel and used my rotors, everything bolted up no problem. The SG wheel I got was non ABS so I didn`t have to change any bearings.
Hunter1 is offline   Reply With Quote
