Dark Primary oil after rebuild and 35 miles : V-Twin Forum: Harley Davidson Forums
Old 12-03-2012, 07:13 PM   #1 (permalink)
Kd4xr's Avatar
Kd4xr is on a distinguished road
Just finished rebuilding clutch, installed new compensator spring and cover, new primary chain tensioner foot, and new chrome inner primary with new mains haft bearing and race. Took it out for a test ride everything seemed ok except for an oil leak from the primary drain plug. Pulled the plug to install a new o-ring and noticed that the primary oil had already turned dark gray after only 35 miles. No metal shavings on the drain plug but I wonder if the dark gray oil is normal?
Kd4xr is offline   Reply With Quote
Old 12-03-2012, 07:27 PM   #2 (permalink)
lonslo is on a distinguished road
No problem. New plates are soft , porous, and dry. It takes a while for them to glaze over and get harder and oil soaked. Just the "dust" coming off of them.
lonslo is offline   Reply With Quote
Old 12-03-2012, 09:59 PM   #3 (permalink)
BUBBIE is on a distinguished road
Could be another reason here...
Does or Did the oil smell BURNT... Stator problems turn oil Dark and Really Stinks like from the burnt wires...
signed....BUBBIE
BUBBIE is offline   Reply With Quote
Old 12-04-2012, 06:20 AM   #4 (permalink)
Kd4xr's Avatar
Smile
I have experience with oil burnt by the the stator. That's a smell you wont easily forget. I'm happy to say it is not electrical.
My first thought was the new clutch friction plates but since this was my first "Primary Rebuild", I wasn't sure. There are some things that you learn only by experience. It makes sense that there would be a certain amount of material coming off of the new friction plates and that material would end up in the oil.
I'll run it for 500 miles - that will be 4 days in my case - then change the primary oil.
Old 12-04-2012, 07:19 AM   #5 (permalink)
Swamprat Rider
JayFL459's Avatar
JayFL459 is on a distinguished road
Thumbs up
Sounds like a good plan ..
2000 FXR4 2000 FXR4/2012 Vic Cross Country
JayFL459 is offline   Reply With Quote
Old 12-04-2012, 04:47 PM   #6 (permalink)
Ironbutt
MilesToGo's Avatar
I agree. It doesn't take long for the primary oil to get dirty, especially with new clutch plates. Can't believe that Harley use to cycle this oil with the engine.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
