oil usage : V-Twin Forum: Harley Davidson Forums
Old 11-30-2012, 03:54 PM   #1 (permalink)
hardheaded is on a distinguished road
oil usage
2012 streetglide 2900 miles,just used 4oz. of oil in 1000 miles.wanna think?
hardheaded is offline   Reply With Quote
Old 11-30-2012, 04:44 PM   #2 (permalink)
not sober all the time
Uncle Salty will become famous soon enough
Not bad.
Uncle Salty is offline   Reply With Quote
Old 11-30-2012, 05:55 PM   #3 (permalink)
Mike02's Avatar
Mike02 is on a distinguished road
Not good
Originally Posted by Uncle Salty View Post
Not bad.
Certainly not good...
Mike02 is offline   Reply With Quote
Old 11-30-2012, 06:28 PM   #4 (permalink)
Assuming the consumption remains constant, that's a half quart in 4,000 miles. I wouldn't get excited about that.
Old 11-30-2012, 07:13 PM   #5 (permalink)
Just pidlin'
CHIPMAKER's Avatar
CHIPMAKER is on a distinguished road
I always wonder if people check their oil by the book. That means: allow engine to idle for 2 minutes, then shut off and check the oil level.
In any confrontation between knowledge and ignorance, ignorance has the edge,
because knowledge is limited, but ignorance is not......
just pidlin
CHIPMAKER is offline   Reply With Quote
Old 11-30-2012, 09:24 PM   #6 (permalink)
COOLFXDC is on a distinguished road
4 oz could just be from different temps when checked. Maybe it was a bit overfilled from the start to.
Just keep your eye on it and check it the same each time. On my 11 King it took about 8000 miles before I could really tell how much it uses. Mine runs about 1 oz per 1000 miles, even now I still get a little variation.
COOLFXDC is offline   Reply With Quote
Old 11-30-2012, 09:37 PM   #7 (permalink)
this is the way i always do it .i changed oil 900 miles ago rode it and got it hot and check and it was right on the full mark,rode it today and was hot when i got home and took 4oz. to bring back to full mark.just seems like alot to me ,maybe get better with more miles?
Old 12-01-2012, 10:50 AM   #8 (permalink)
RKC-Charlie is on a distinguished road
4 oz is nothing to be concerned about, and no need to top off if it is slightly down. I'd ride it 3000 to 4000 miles, then check it. Or simply change it and start again. As mentioned, always check hot and after a couple minutes of ideling.
Mine: Road King Classic, Street Bob, Forty Eight
Ride with an attitude
RKC-Charlie is offline   Reply With Quote
Old 12-05-2012, 03:02 PM   #9 (permalink)
My 2010 96" Street Glide does not use any oil between changes? The last bike that I owned that used any oil was a 1972 FLH. It used a little oil between changes until I put valve seals in it. Personally, I don't think any newer bike should use oil between changes. I know some do, but I don't think they should.
Old 12-05-2012, 04:29 PM   #10 (permalink)
Ironbutt
MilesToGo's Avatar
Originally Posted by rickr01 View Post
My 2010 96" Street Glide does not use any oil between changes? The last bike that I owned that used any oil was a 1972 FLH. It used a little oil between changes until I put valve seals in it. Personally, I don't think any newer bike should use oil between chanes. I know some do, but I don't think they should.
Some oil gets used in the combustion process but it should be minimal. My oil gets changed every 3k and i see hardly any oil usage in between changes - maybe 1-2 oz.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
