Looks good. Did a tank lift on mine a while back. Two things to think about, one- watch your tank, the bars on mine hit the tank right before they hit the stops but then I'm running some custom apes. Two- fuel gauge is going to be off, mine would show empty and dash light comes on but I still have a little over a gallon still in the tank. That might be a good thing as you start looking for a gas station sooner. Gives the bike a little different look but not sure it helps any with the heat issue or it didn't as much as I was hoping. Easy straight forward install.
2010 SG
PCV
V&H Power Duals
V&H Monster Ovals
SE Stage I Cleaner with K&N Filter
Andrews 48H Cams
Polk Audio MM651
Rockford Fosgate PBR300X2
