Another whining noise constitent with RPM : V-Twin Forum: Harley Davidson Forums
Old 11-22-2012, 08:50 PM   #1 (permalink)
i8avet is on a distinguished road
I went on a 300 mile ride today. About 75 miles to go I topped off my tank and when I started my bike there was a loud whining noise. The noise is constant with enging rpm. Was never there before. I pulled the primary because I thought the chain rubbed through the guide. Not the case. Slack is good, not too tight not to loose. I put a stethascope by the cams and thats where it seem to be the loudest. I have no mods on the bike. the bike is a '99 electra glide ultra. any ideas?
i8avet is offline   Reply With Quote
Old 11-22-2012, 08:53 PM   #2 (permalink)
93Horse's Avatar
93Horse is on a distinguished road
How many miles? 99 bike... does it have the original cam bearing?
"Our lives begin to end the day we become silent about things that matter"
93Horse is offline   Reply With Quote
Old 11-22-2012, 09:00 PM   #3 (permalink)
38K. Im 3rd owner I assume everythings original
Old 11-22-2012, 09:24 PM   #4 (permalink)
not an evo. its first gen v-twin
Old 11-22-2012, 10:16 PM   #5 (permalink)
Rollmeaway's Avatar
Rollmeaway is on a distinguished road
I think I would be pulling the cam cover & checking for any discoloring of the internal parts. It maybe a bearing on its way out. Check the mesh on the chain.
We never even said a word,
And we rolled...
Dare...
2000 FXST - Carbed
Rollmeaway is offline   Reply With Quote
Old 11-23-2012, 12:10 AM   #6 (permalink)
i pulled the cam cover and half of the orange guide fell out. The spring tensioner on the bottom is bent and cracked (probably from riding the chain). thanks for all your input. UPGRADES HERE I COME!!!
Old 11-23-2012, 01:08 AM   #7 (permalink)
brother is on a distinguished road
Inspect the rear bearing surface on your cams good too. My inner cam bearings on my 06 started taking out the cams at 32,400 miles.
brother is offline   Reply With Quote
Old 11-23-2012, 01:18 AM   #8 (permalink)
I'm looking for new cams as we type
Old 11-23-2012, 07:11 AM   #9 (permalink)
Look for the upgraded cam plate as well.
Old 11-23-2012, 03:15 PM   #10 (permalink)
ultraplusrotax's Avatar
ultraplusrotax is on a distinguished road
1999 is either an EVO-engine or a Twin Cam.
And the first generation V-twin was called the F-Head (untill 1929) then came the Flathead, Knuckelhead, Panhead, Shovelhead untill 1984 and then the EVO, to be replaced by the Twin Cam in 1999.If you are confused about all those names look on Facebook at Iron Butt, more than 1.000 pictures from 1903 untill 2013. Please send a picture of your H-D on my Iron Butt-account on Facebook http://www.facebook.com/iron.butt.9?...#!/iron.butt.9
ultraplusrotax is offline   Reply With Quote
Old 11-23-2012, 05:19 PM   #11 (permalink)
Rollmeaway's Avatar
Dude ... take a deep breath ... seriously do you think for a minute the man is confused on what is between his legs .....
And we rolled...
Dare...
2000 FXST - Carbed
Old 11-24-2012, 11:17 AM   #12 (permalink)
I ment twin cam. Thanks
Old 11-30-2012, 07:22 AM   #13 (permalink)
BUBBIE is on a distinguished road
LOOK at the Build date of bike
If you Look at the front frame down tubes (squating from right side looking thru to left), you will find a sticker saying Build Date.
IF it was Built in 99/dec. You have the problemed BALL bearing in the rear cam plate to replace also...
The beariing only got replaced by HD when it totally went out.
(I did mine when apart)
HD promised way back when they became a Problem of Blowing up,,,,to replace it for free IF it exploded on any owner of date...BUT when I sent a owner to get their Warranty,,, "Sorry Charley" too Late... So WE have to replace them... Better before they become a problem.
If it has the 00/jan or later date, that bearing is a Roller and should not pose a problem.
The Shoes, (two places), one in front as you have found and the other in the rear of the cam plate
(condition can be seen there with using a small dental mirror if cam-plate not apart)
The older bikes do fine Switching to Gear Drive cams.
IF the cranks run-out is about .001 and max of .003 (I prefer Less than .003 and find Most at .001 to .002, then like going gear drives on the cams.
Another replacement Usually done at this time is the INA (engine cam bearings) changed out to the full needle roller style. Not expensive but Careful removing and replacing them.(special puller and driver are good tools to have)
Easiest and works Good:
IF you go with the Hydraulic tensioners,,,,, IMPROVED cam-plate and High Volume oil pump with other parts in the HD "KIT"...
You will be updated to the newer style cam tensioners that HD uses today but still have the 4" stroke.
If you need or want More information, I'd be happy to answer any questions on this as I Had a 00 early 1/2 year model and did Many good things to it.
signed....BUBBIE
BUBBIE is offline   Reply With Quote
Old 11-30-2012, 09:10 AM   #14 (permalink)
Talking
Thanks for the info Bubbie.
Heres what I found when I opened the cam cover
Bouncing off some ideas this is what ive chosen to do on my bike.
95" big bore.
All new gaskets and compression releases.
Includes:
10.5:1 se hi comp se pistons.
Hydraulic se cam plate kit with hi flow oil pump
Black Widow 55 cams
Se compression releases (manual)
Kibble white oversized valves
Comp cam springs
Complete can service gasket kit (hd)
Se inner cam bearings
New hd secondary cam chain
New hd lifters
Se adjustable push rods
Im also changing to V/H dual headers
Big Sucker air cleaner
Dyno Jet Power Vision.
I think this will be fun to ride
Old 12-01-2012, 12:56 PM   #15 (permalink)
Questionb on the cams? Intake Close*
Looks like your on the right path.
I don't know the intake close on the cams you are using...
Need to konw that for My opinion... Intake Close* has a lot to do with the compression NEEDED to operate the motor. My prefrence= 180 to 190 lbs of compression seems to work best for todays 91 junk we get. AND the alititude you are from sea level
IF your just tossing pistons into the mix at 10.5 X 1, Careful and ? on the Squish distance and CC in/on the heads.
IF intake closes about 40 -46 * ? you may be Okay..
Give me the * of intake close and I'll run the numbers you are showing here.
signed....BUBBIE
