My 2010 RKC was loose when I bought it, the dealer had to adjust it at the 1000 and at about 2500, then they had it in for 5000 and it was loose again, later I was changing the oil and thought I would check it and the thing was loose again. I do have 18000 miles and it has stayed in adjustment. The manual states to lift the front end and the bike has to be level with the stock items as the factory sent it, the prosses is long the way the manual wants you to do it, first step grease it, you would have thought they did that at the factory, a spash is good for them.
