11-16-2012, 08:25 PM
Switching to mini apes from stock
I have a 2011 FLHTP. I am some what mechanically inclined, probably just enough to get my self into trouble. I have already added a stereo and speakers. I am looking to switch bars, but am a little intimidated. I am sure there are those of you who have tackled this. I have a friend that has a set for a fair price and comes with the brake and clutch cables. My question is will the stock wires still work or am I looking at extending everything? Any help or suggestions for a newb?
11-20-2012, 07:33 AM
You will more then likely need to extend the wires. They sell kits on ebay.
11-20-2012, 03:37 PM
Any one done this?
Any kits recommended? Any to shy away from?
Thanks for helping a newbie!
11-20-2012, 05:07 PM
Ironbutt
I put some 12 in apes on my Street Glide and i had to extend everything. I purchased everything i needed from Direct Harley Parts. Send me your email addy and i'll send you some DIY info.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
11-20-2012, 06:01 PM
i installed 10" paul Yippes "BAGGER" bars" on my '09 tri-glide & the stock wireing was ok. just had to use a 10" TBY extension & a 4" over clutch cable. if you cut off a allen-wrench you can remove the trans cover with-out removeing the exhaust.
if you plan on "internal wireing" then don't get the APE brs , because the sharp bent
(90*) is too tight to get the TBY cable thru. i'm just under 6' tall, with a ruler under my arm pit to where the wrist hinges is 23". and i can lean back on the back rest & comfortably reach the handle bars. i just cut-off some metric allen wrench's & glued them in the appropriate shallow 1/4" sockets .it helps if you have some place to tie the inner fairing up to ( i used a rafter. ) not a hard task, just a couple of days working onn and off. on the new clutch "O", just lightly butter lube it with permatex non-harsning sealant & use only BLUE threadlocker . just search this & other sites for some good pictures as others have done this. my play-by-play on triketalk is gone as the site was hacked. try hd talking forume.
as i am r&r my t/g handlebars to 10" paul Yippes, heres what i,ve learned.
1. if you plan to R&R the riser bushings to polyurathane.
takes 3/4" 6 pt. shallow socket.
after you take off the outer fairing remove the left.
riser mount bole as you will have to turn the wheel full right to access the bolt
from inside the front of the fairing.
2. take out the radio. cut off a 1/4" (metric) allen wrench about 3" long
( to remove radio mount bolts.)
& glue into a 1/4" drive socket.do the same for a 3/16 allen wrench (metric) only 1" long
you will also need a 5/32 allen wrench.
3. buy a new tube of blue threadlocker.
4. as i am solo. park the bike under a ceiling truss, so you can tie a string to it
& hold the inner fairing up when you get it loose.
5. after you get the radio out you will see that if you remove both riser mount bolts
the handle bars fall free. so tie the bars up (keep them from falling on your tank. )
then you can remove the handlebars & risers as a assembly.
6. if you have to remove the ign. switch, make a ign. special tool. thats in the video.
this prevents numerous times removeing and installing the switch.
7. the hardest part is installing the chrome skirt on the front forks.
really fits tight. fought that for 2 hrs today & still didn't get it.
8 don't forget to grease the neck zerk. mine was dry when the bike was new . also w week later use kleenex to wipe out the excess grease.
also take apart all elec connections on the bike & put a dab of dielectrical grease in them. this prevents any chance of moisture
getting into them & causing corrossion. fuses too. hope you have changed out the tranny "syn "3 to a better gear lube like spectro or red line. leon
Reason: more info.
11-20-2012, 06:25 PM
Waiting for winter to really settle in here in Michigan to tackle this. I am little more apprehensive about the swap after the feedback. I have purchased the bars. I am going with internal wiring, and the clutch and brake cables are braided stainless and will not be internal.
11-20-2012, 07:11 PM
This video seems to go pretty quick. Any tips to help? Anything they skipped by that i should pay particular attention to?
I need to get service manual!
11-21-2012, 05:06 PM
Ironbutt
Originally Posted by B1gfun
Good video...i've seen it before. I sure wish this job could be done in 13 minutes. It does show a lot of the major steps though and gives you some idea of the overall task involved. They just leave out all the little details that always cost time. Just the simple task of removing the pins from the plastic connectors can be a real pain if you haven't done it before. Like i said, this is good 6-8 hour job even for someone that's done it before.
Tips? Make sure you protect all your paint when removing any brake lines. Dot4 fluid will eat through any paint quickly.
2009 Street Glide
11-21-2012, 08:40 PM
Thanks Miles.
I am hoping for any and all tips. I know its going to take me at least two days. I am trying to get as much info as i can. Hoping anyone else can chime in and give some insight. Thanks again to everyone thus far. keep it coming!
11-22-2012, 11:38 AM
A couple quick obvious tips.
Stagger your solder joints so they aren't all in the same spot when extending wires. When heating the shrink tubing, do so until a bit of the sealant goo beads out each end. Best of luck.
11-25-2012, 06:09 AM
What size bars where installed in that video?
11-25-2012, 12:55 PM
Here is my cycle smith 13" bars. Kinda wish I went with 16"s.
2012 CVO Ultra. And loving it !!!
06 Dyna Lowrider...Sold..Gone,but not forgotten...
11-26-2012, 02:36 AM
When you pull the wires from the plugs, do so one at a time and replace with the maching exstention wire outherwise you could lose track of what color wire goes were. Its eather that or draw a pic of the plug and which color wire goes were.
2005 FXD 117ci (one ugly fast bike)
2001 FLHTC S&S 126ci (now running)
2001 FXDXT (new York rust bucket being restored)
11-26-2012, 08:47 PM
Saved by Christ
Too nerve racking for me ...I got cash to spend...let Harley do it and be responsible for the work...get something wrong and you are screwed...
 2013 RoadKing...Midnight Pearl...ABS,Cruise & Security...SlipStream Collection...440 HD 12"...Fullsac headpipe...CVO slipons w/2" Fullsac cores...Limited Wheels...
11-27-2012, 05:08 AM
Lol. I did my Dyna low rider that was not too bad, no faring. But with this ultra and TBW no way was I touching that and only 2/3 months old. Lol.
| Sponsored Links |
