2008 Touring Rear Pulley Change : V-Twin Forum: Harley Davidson Forums
Old 11-13-2012, 06:44 AM   #1 (permalink)
mainmusic's Avatar
mainmusic is on a distinguished road
I'm thinking of changing my rear pulley on my 08 RG from the stocl 66 tooth to the sportster 68 tooth. I want to keep my IDS and from what I see guys are using the 40518-07 pulley that comes with a bearing that seem to be for IDS. I already have IDS on my bike and have found a lot better price on a 40354-07 it is a 68 tooth for 07 up sportster. Anyone know if the 40354-07 will work with my IDS that I aready Have on my bike? I'm just not sure if there is a dofferance in the IDS Pulley and a non IDS Pulley
2003 Road King Classic
98" Jugs
Screamin Eagle Mod. Heads Cleaned up
Custom JE Forged Pistons
Woods tw7G Cams
S&S Gear Drive
Crank Trued and Welded
B Lifters
Baker 6 Speed Overdrive
Rinehart True Duals
3:37 Primary
Thundermax
2008 Road Glide
107 CI
Woods 777 cams
Heads by WFO Larry
30 tooth Trans Sprocket 68 Tooth Rear
Rinehart True Duals
Thundermax
mainmusic is offline   Reply With Quote
Old 11-13-2012, 12:24 PM   #2 (permalink)
Barney Biker is on a distinguished road
I have the 40518-07 on my 07 EG but they came stock without the IDS.
Don't know about your part number?
Barney
Barney Biker is offline   Reply With Quote
Old 11-25-2012, 08:15 PM   #3 (permalink)
Bud Murray is on a distinguished road
Check out this link everything you need parts wise is listed. http://www.hdforums.com/forum/tourin...nd-08s-10.html
Bud Murray is offline   Reply With Quote
Old 11-26-2012, 07:42 AM   #4 (permalink)
Cub Guy is on a distinguished road
WTF is IDS?
Cub Guy is offline   Reply With Quote
Old 11-26-2012, 12:57 PM   #5 (permalink)
Originally Posted by Cub Guy View Post
WTF is IDS?
Isolated Drive System. Stock on 08 and up.
Old 11-26-2012, 01:02 PM   #6 (permalink)
If you haven't already figured it out, you need the 40518-07. It's the Japanese Sportster 68T IDS pulley.
Old 11-26-2012, 02:43 PM   #7 (permalink)
qtrracer is on a distinguished road
I think you mean the 40518-08. As you stated he already knows all this but I guess he thinks if he keeps asking that same question on every forum someone will tell him that the cheaper pulley will work, lol!
"You have to inspire yourself. I am my own role model. I want to be me." Vincent Lepak 2008
qtrracer is offline   Reply With Quote
Old 11-26-2012, 03:19 PM   #8 (permalink)
The 40518-07 is for the 07 year and the 40518-08 is for the 08 models.
Each comes with the proper bearing.
Barney
Old 11-26-2012, 03:59 PM   #9 (permalink)
grof is on a distinguished road
pullie
hi,
why you do this, what is the point. are you racing, save gas, get speed etc. can you explain pls.
grof is offline   Reply With Quote
Old 11-26-2012, 04:14 PM   #10 (permalink)
Barney
My -08 pulley came with the 9254 bearing and needed to changed to the 9285 bearing for my 08 FLHX. The bearing would have been proper had I been installing the pulley onto an 08 Japanese Sportster.
Old 11-26-2012, 08:53 PM   #11 (permalink)
Originally Posted by grof View Post
hi,
The 07 and 08 bikes are under geared. Adding a couple teeth makes the gearing better, particularly 1st and 6th gears.
Old 11-27-2012, 12:53 PM   #12 (permalink)
My bad, My bike is an 07 and it came with the right bearing for it.
The 07 models have a 1 inch axle and the 08 models have a 25 MM axle.
Haven't changed an 08 model but my 07 worked like it was made for it.
Barney
Old 11-27-2012, 01:08 PM   #13 (permalink)
In the case that happened to me it was the race width that was incorrect as both bearings are 25mm.
