Starting From Scratch Opinions On My Mods : V-Twin Forum: Harley Davidson Forums
Old 11-11-2012, 03:58 PM   #1 (permalink)
lhgdale is on a distinguished road
Hello, I just got a 2013 Ultra Limited and would like your opinions/suggestions on the performance mods I have planned.
My goal for the bike bike is 100 ft lbs of torque or a little more. Intake: Zippers Max Flow or Harley Stage 1, tune will be a Power Vision map from Fuelmoto and exhaust I am between the new Fuelmoto 2-1 Pipe, D&D Boss Fat Cat or Suppertrapp Supermeg.
Thanks!!! Any info or suggestions are greatly appreciated.
lhgdale is offline   Reply With Quote
Old 11-11-2012, 04:22 PM   #2 (permalink)
Ironbutt
MilesToGo's Avatar
Sounds like you have a good plan. Any of those pipes, with a good tune should get you close to your goal. I'm running the D&D pipe on my Street Glide. It's a great pipe with a nice deep tone.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
Old 11-11-2012, 04:31 PM   #3 (permalink)
Thanks, I think that # is realistic with the right setup. Are you running the performance baffle? I have read you will loose power with the quiet.
Old 11-11-2012, 05:35 PM   #4 (permalink)
semi-retired
FatBobRob's Avatar
FatBobRob is on a distinguished road
That should be easy with a low lift cam,Se 204 or a Crane 1-6000.
I can't means I won't!
FatBobRob is offline   Reply With Quote
Old 11-11-2012, 05:59 PM   #5 (permalink)
No cams, at least not yet.
Old 11-11-2012, 07:01 PM   #6 (permalink)
smitty901's Avatar
smitty901 is on a distinguished road
Mods are a personalthing but you ask.Fuel moto headers and super traps.
You may want to look at the HD night sticks come in black or chrone and may save you a few bucks ompare them to the super traps
Infantry leads the way
smitty901 is offline   Reply With Quote
Old 11-11-2012, 08:30 PM   #7 (permalink)
Thanks, I'll check them out. I saw some dyno #s for a similar setup with the supertrapps and the bike was making around 103 ft lbs. The torque was over 90 at 2500 rpm.
Old 11-12-2012, 04:19 PM   #8 (permalink)
Ironbutt
MilesToGo's Avatar
No, i have the wrapped baffle. Unless you like LOUD, don't order the performance baffle.
2009 Street Glide
Old 11-12-2012, 04:54 PM   #9 (permalink)
DK Custom's Avatar
DK Custom is on a distinguished road
If you get an air cleaner that does NOT feed the hot dirty oily air from the engine back into the combustion chamber, that will give you a 3-5% bump in HP & Torque. Plus you won't have carbon build up on your pistons.
DK Custom is offline   Reply With Quote
Old 11-12-2012, 05:33 PM   #10 (permalink)
Would this be like the zippers air filter setup? I know some have the hoses that direct the oil back into the intake I believe the zippers does not do this.
Old 11-12-2012, 08:34 PM   #11 (permalink)
brassman's Avatar
brassman is on a distinguished road
Crane 1-6000
brassman is offline   Reply With Quote
Old 11-13-2012, 01:35 PM   #12 (permalink)
DK Custom's Avatar
I believe all the zippers a/c are directing the dirty hot oily air back into the intake. They are doing it internally via passages in the housing.
There are very few companies still making true Stage 1 Air Cleaners that ONLY allow clean air into the intake.
All the OUTLAW HiFlow 587's do so.
They come with one of two external breather systems-
Or the traditional hose and filter
Old 11-13-2012, 05:30 PM   #13 (permalink)
How does it flow compared to other filter setups? I did a search and not much info or user reviews of the setup.
