2012 Ultra Limited - Cylinder Shut Down : V-Twin Forum: Harley Davidson Forums
Old 08-26-2012, 06:43 PM   #1 (permalink)
boston62's Avatar
boston62 wants to know Dino or Syn?
Is there anyway to stop the cylinder from shutting down, when it gets to hot... I was told that the cylinder will shut down when at a stop, to keep it from over heating. Is that true? Thanks
boston62 is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 06:56 PM   #2 (permalink)
duty2's Avatar
duty2 wants to know Dino or Syn?
It should be in the owners manual on how to change it. But why would you want to?
duty2 is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 07:34 PM   #3 (permalink)
Slider1950's Avatar
Slider1950 wants to know Dino or Syn?
Yep there is a way to shut it off.
Look in the "Operation" section of your manual.
Project Appleseed, reviving American Patriotism one person at a time.
Slider1950 is offline   Reply With Quote Quick reply to this message
Old 08-26-2012, 07:42 PM   #4 (permalink)
autoworker's Avatar
autoworker wants to know Dino or Syn?
Engine off,key on,twist throttle past the closed position and hold,look for dash light to momentarily light,return throttle to resting position.To turn it back on repeat.
That's how it works on a 2010.I figure it is still the same on a 2012.
Motorcycle Poor
autoworker is online now   Reply With Quote Quick reply to this message
Old 08-26-2012, 07:53 PM   #5 (permalink)
boston62's Avatar
After reading about in the manual, I see the logic behind it, with the fairing, and lowers, it needs airflow over the motor, and living in Florida, it gets hot. I'll keep it on, but thanks to everyone that replied.
Sent from my iPhone using MO Free
Old 08-26-2012, 09:50 PM   #6 (permalink)
Oldman47 wants to know Dino or Syn?
I never knew that mine was working until I got stuck in a traffic jam at some construction in St Louis on a 95 degree day. Then I used the rear cylinder shutoff as a warning that things were getting out of control on temperature. I shut the bike off except when I wanted to move it. It was off about 5 minutes for each minute it was running and I bet it helped save some excess wear by me heeding that warning of the rear cylinder shutting off. I ended up with a push mobile for about an hour or so but the bike still runs great today. Being aware of the warning signs that your bike gives you may well save you lots of expensive engine work.
Oldman47 is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 05:58 AM   #7 (permalink)
Phuck around and find out
Scrubs's Avatar
Scrubs is reading this now saying WTF is this? Scrubs is reading this now saying WTF is this?
During this Overheat/Parade mode, aka Rear Cyl. Shutdown does the injector continue to deliver fuel to the combustion chamber? What happens to this unspent fuel? Does it just evaporate in the residual heat of the cylinder head? Just wondering since I don't own an FLHT...yet.
Scrubs
USAF MSgt (Ret.) nineteen & ninety - twenty ten
Scrubs is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 06:28 AM   #8 (permalink)
boston62's Avatar
The injector is shut off, and the piston acts as an air pump, according to the manual.
Old 08-27-2012, 04:23 PM   #9 (permalink)
Hammerhead Pat wants to know Dino or Syn?
The first time it goes off on you is a WTF moment
Hammerhead Pat is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 04:26 PM   #10 (permalink)
boston62's Avatar
Yes I know been through it at a red light, used those same words.
Sent from my iPhone using Motorcycle
Old 08-27-2012, 05:03 PM   #11 (permalink)
What do you mean FNG :)
Firechief510's Avatar
Firechief510 wants to know Dino or Syn?
The wife loves the extra vibration...
2009 Street Glide
Black Pearl
Stage 1 kit
Rinehart exhaust.
Firechief510 is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 07:10 PM   #12 (permalink)
I HATE 'bing'...
TriLs's Avatar
TriLs wants to know Dino or Syn?
The "official" term in 2009 was EITMS:
Engine Ignition Temperature Management System
The acronym helps to de-stigmatize it to some degree, I suppose. It is apparently triggered by the head temp, not the oil since I have had it kick in when oil was at 210*.
Note that in a VERY slow parade, even that doesn't work and the engine starts sounding like a dryer full of spark plugs. Very embarrassing with a local beauty queen on the back waving to the crowd...
Tri
____________________________________________
"It ain't what you don't know that gets you into trouble,
it's what you know for sure that just ain't so..."
Mark Twain
Live well...Love faithfully...Laugh often.
"Spirit", a Vivid Black '09 TriGlide, 103" stock, V&H Dresser slipons,
SE Stage 1 A/C, SERT, fairing-mounted oil temp, Zumo 660, small
bits o' glitz, and HD foggies on dedicated foot pegs.
http://www.ecclesia-ministries.org
TriLs is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 07:34 PM   #13 (permalink)
59panhead wants to know Dino or Syn?
take off the stock oem cat exhaust add a 2-1 pro pipe fulpack and k&n air-filter and run a good 20-50 amsoil or spectro oil in the motor and a full syn gear lube 70/140 in the trans
turing that stupid rear cylinder mode off is a good thing Im surprized H-D even tells us how to do that
plus I agree with boston 62 about all that plastic on the bike keeping air from getting to the engine
59panhead is offline   Reply With Quote Quick reply to this message
Old 08-27-2012, 11:09 PM   #14 (permalink)
blubyubusa wants to know Dino or Syn?
rear cylinder "kill"
Do all the newer bikes have this feature or function or is it just on the touring bikes with a lot of fairing?
blubyubusa is offline   Reply With Quote Quick reply to this message
Old 08-28-2012, 11:20 AM   #15 (permalink)
FLYM92 wants to know Dino or Syn?
Amazing the number of people that do not read their owners manual...l
FLYM92 is offline   Reply With Quote Quick reply to this message
