Detachable tour-pak help : V-Twin Forum: Harley Davidson Forums
Old 08-10-2012, 07:07 PM   #1 (permalink)
LEO & NRA
Vettely is on a distinguished road
Today I got a "detachable tour-pak kit for electra glide classic" #533303-07 so I could start using my tour pak (2004). I have a detachable sissy bar I've been using for several years. The two do not match. If you notice the sissy bar mount points are farther apart and the mechanisms are on the out side and on the tour pak part they are on the inside. The tour pak piece will not fit over the chrome top frame covers either. I would hate to have to buy another sissy bar. Whats going on here? I could use sure use some help please.
PEACE THROUGH STRENGTH
Vettely is offline   Reply With Quote
Old 08-10-2012, 07:28 PM   #2 (permalink)
lumpy38's Avatar
lumpy38 is on a distinguished road
On my 06 Glide I had a detachable backrest and the matching kit installed. A year later I decided to install a detachable tour pak. The detachable tour pack mounts are different than the detachable backrest mounts, as you can see by your pic. Now you have to buy a different kit to mount the tour pak. You cannot switch between backrest and tourpak, it's one or the other.
I went with the tourpak, the backrest is still hanging up in the garage.
06 FLHTPI -95" Heads 82cc & Jugs massaged by Bean
Edelbrock +5 JE Sportsman Pistons - Crane 300 Cams
SC=9.5 CC=9.0 CCP=190 Hiflo OP & Baisley
.030 Cometic + .010 in the hole = .040 squish
SE Fatshots - 15 discs closed ends
83/83 tuned at BigBoyz
lumpy38 is offline   Reply With Quote
Old 08-10-2012, 07:35 PM   #3 (permalink)
Chart is on a distinguished road
Take your pictures into the harley parts department, and they will get you set up with the mounting brackets needed to make the tour pack fit on your bike.
Chart is offline   Reply With Quote
Old 08-10-2012, 08:09 PM   #4 (permalink)
LEO & NRA
What? Really. The reason I shelled out another $300+ to HD was so I could use both.
Damn. I can swear the salesman said he uses the sissy bar and pak on his personal ride. I really do not want to have one OR the other.
Old 08-10-2012, 09:55 PM   #5 (permalink)
Lefty's Avatar
Lefty will become famous soon enough
I have both a detachable tour pack and sissy bar/pad, using the trunk only when traveling with the missus. Your problem may be that you have two point mounting hardware and you need the four point system. The 2 or 4points don't include the built in forward mounting points that are a part of the bike. My bike is a 2011. Road glide. No idea if this is relevant to yours.
Sent from my iPhone using MO Free
Gold is the currency of kings - Silver is the currency of gentlemen - Barter is the currency of peasants - Debt is the currency of slaves - Norman Franz from Money and Wealth in the New Millennium
Lefty is offline   Reply With Quote
Old 08-10-2012, 09:59 PM   #6 (permalink)
Don't have the part number handy but there is another set of mounts you nee to install. About $25.
Old 08-10-2012, 10:11 PM   #7 (permalink)
Barney Biker is on a distinguished road
You have to have a set for the backrest and a set for the tour pak both. You can have the mount points on at the same time and use one or the other the tour pak or the backrest.
Does that make any sense?
Barney
Barney Biker is offline   Reply With Quote
Old 08-10-2012, 11:49 PM   #8 (permalink)
LEO & NRA
Perhaps there is hope. My current set up does look different from what I have seen on line.
Thanks for giving me hope guys.
Old 08-11-2012, 03:47 AM   #9 (permalink)
Magnum44 is on a distinguished road
As far as I know, at least in my 2003 RK, the mount point closer to the seat where you lock the end of the tourpack or the sissy bar, is the same, this is why you cannot have both at the same time. It would be nice to be able to have both but the weight would be a lot. I have problems now with the saddlebag support kit breaking because of the vibrations and the weight. For my RK I don't think it will work.
Magnum44 is online now   Reply With Quote
Old 08-11-2012, 10:03 PM   #10 (permalink)
LEO & NRA
Just for clarification, all I want is to be able to switch between sissy bar no TP and TP no sissy bar. Not both at same time.
Old 08-12-2012, 08:33 AM   #11 (permalink)
DarbinCo's Avatar
DarbinCo is on a distinguished road
This is correct. With the right mounting hardware you can switch between the tour pak and a back rest in seconds. I had both on my 07 RG. I should have just saved the money though and bought a regular non-detachable solid TP mount. Once I had the TP on the bike, it was so handy to have I never took it off.
If memory serves me right the part your going to need it on page 359 of the 2012 P&A catalog. It's (C) at the top of the page 53803-06 or 53804-06 It allows different docking points for the backrest and TP. The TP cant use the same points as the BR because it would too far forward and the passenger wouldn't have much seat left.
Double check me with your parts guy as I've been known to be wrong before but I'll bet this part will get you going.
On Edit...
Geoff listed both part numbers below and depending on your use it could be either so I changed my post here to reflect it also.
The headlights on your truck don't turn with the steering wheel do they?
DarbinCo is offline   Reply With Quote
Old 08-12-2012, 09:34 AM   #12 (permalink)
Geoff of NV's Avatar
Geoff of NV is on a distinguished road
Touring Detachable Docking Hardware Kit
Kit contains the docking hardware necessary to install Detachable accessories on your Road King®, Road Glide®, Street Glide® or Electra Glide® Standard model.
Docking Hardware Fitment Matrix
This product is available in multiple variations. Be sure to look for the one that fits the specific model and year of your motorcycle.
53803-06
Sissy Bar Upright or Solo Tour-Pak® Rack
Fits '97-'08 Touring models (except FLHTCUI, and '07-'08 FLHRSE3/4).
MSRP US $41.95
53804-06
Two-Up Tour-Pak® or Two-Up Luggage Rack
MSRP US $59.95
Riding with friends,
Geoff of NV
Geoff of NV is offline   Reply With Quote
Old 08-12-2012, 10:48 AM   #13 (permalink)
lumpy38's Avatar
After reading this thread through again this morning, I was wondering why I didn't have the capability of using both my tourpak and backrest. I don't know where I initially got this idea.... hence my previous post. The more I thought about it, the more pissed I got so I went out to the scoot to take another look. What a dumbazz!!!!1 I took off the tourpak and dusted off the ol backrest and VOILA' ( I think this is french ) the backrest went on. I take the tourpak off when I'm riding solo with the guys and I never attempted to put the backrest on. I am both embarassed to be a chump ( not the 1st or last time) and happy to find out I can use both! I dug out my records and took a few pics, I hope they help someone. The part numbers are in the pics. I just want to thank all you guys that post on this forum, this is the best place to get info and swap experience with other knuckle busters.
ID:	73568   Click image for larger version
ID:	73569   Click image for larger version
ID:	73570   Click image for larger version
Old 08-12-2012, 03:49 PM   #14 (permalink)
LEO & NRA
Thanks Guys. I think the mystery has been solved. Going to head over to the parts dept. and follow up on this. Thanks for all the help.
Old 08-12-2012, 07:47 PM   #15 (permalink)
"Jane you ignorant slut!"
ceraaa42's Avatar
It sounds like you got it under control. I was planning to do the same and never did.
This leaves me with a brand new wall mount for the tour pack. Interested?
Candy red sunglow
103"
SE255 cams
SE Air cleaner
Fatcat Quiet baffle
Bagger brace
43 member
