Noise when pushing bike backwards in neutral : V-Twin Forum: Harley Davidson Forums
Old 07-22-2012, 12:15 PM   #1 (permalink)
da-puhi wants to know Dino or Syn?
I have a 2008 Road King with 13k miles and I started to get a noise whenever I roll the bike backwards in neutral. It sounds like it coming from the transmission cover area, but could be from somewhere else. It sounds like a a loose chain on a sprocket and only happen in reverse when the bike is cold or hot. Just got the bike back from the dealer who had it on a dyno to install a Super Tuner for another problem all together. Thanks for any help on this issue.
da-puhi is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 12:21 PM   #2 (permalink)
RKC-Charlie wants to know Dino or Syn?
Is that when the engine is running, shut down or both?
Mine: Road King Classic, Ultra Limited, Forty Eight
Ride with an attitude
RKC-Charlie is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 12:33 PM   #3 (permalink)
RKC-Charlie, I notice it when the bike isn't running, I really can't detect it when the bike is running because of the engine and exhaust noise. Thanks
Old 07-22-2012, 03:03 PM   #4 (permalink)
No Cents's Avatar
No Cents wants to know Dino or Syn?
Have you checked your rear brake pads...if they are bad they will make a sound like you are describing when you roll it backwards.
With 13K on the clock...it might be a good place to look.
Just my 2 cents...from No Cents
117" Darkhorse build...all smiles !!!
No Cents is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 03:07 PM   #5 (permalink)
Incredible
Fatb0y's Avatar
Fatb0y wants to know Dino or Syn?
Could be some grit in you primary area or pads going bad. Wouldn't hurt to check. If you don't find anything there just ride it and take all that apart this winter for a full maintenance routine.
Sent from my Motorcycle iPhone app
Fatb0y is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 04:23 PM   #6 (permalink)
btsom wants to know Dino or Syn?
In neutral I don't think anything in the primary will be moving other than the front pulley and its bearing. So, there is that, rear brakes, belt squeak, and rear wheel bearings. If you have a lift or a friend has one, get it off the ground and rotate the rear wheel until you find the noise. If there is no noise there, check the front wheel.
btsom is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 05:43 PM   #7 (permalink)
ron baumer wants to know Dino or Syn?
possibly the drive belt hitting the belt guard,my does it and yes it is adjusted correctly.
Ron
ron baumer is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 07:16 PM   #8 (permalink)
Harley Ridin' Bow Hunter
Eddie Haskell's Avatar
Eddie Haskell wants to know Dino or Syn?
The inner primary bearing will spin in neutral as well, some last a long time and some not so much.
"Don't initiate, Retaliate" - Bobby Allison
2016 Red CVO Road Glide Ultra
Eddie Haskell is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 07:30 PM   #9 (permalink)
HDSG wants to know Dino or Syn?
"GRIT IN THE PRIMARY AREA" I need some more information on that............
HDSG is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 07:36 PM   #10 (permalink)
DueceDog's Avatar
DueceDog wants to know Dino or Syn?
My bike has done that for a few years. I could never find the source until just recently. I had the bike up on a jack working on something else and rolled the rear wheel backwards...and ah hah! there was that noise. It turned out to be the rear brake pad(s). They were low mileage at the time so I knew they were in good shape. I took a spray bottle and gave the rotor a little shot of water and rolled the wheel backwards. No noise When the water evaporated, the noise was back, only rolling backwards. So, I now just accept it as "normal, they all do that" lol
Vietnam Vet
PGR rider
DueceDog is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 07:51 PM   #11 (permalink)
Dan89FLSTC wants to know Dino or Syn?
The inner primary bearing will not be spinning when the engine is shut off and the bike is in neutral (when turning the rear wheel).
With the engine shut down and the clutch lever released (clutch engaged) the mainshaft cannot turn because it is mechanically linked to the engine (via the clutch), which is not turning.
The countershaft will turn, but not the mainshaft.
The inner primary bearing will spin when the engine is running and the bike is in neutral, it will stop spinning when you drop the bike into gear, and it will start spinning as the clutch is engaged and the bike starts moving.
The inner primary bearing will also spin when you push the bike while it is in gear.
Grit in primary...the primary drive is sealed, no grit getting in there, but grit in the secondary drive around the pulley could be, since that is just about the dirtiest area on the bike.
Best suggestion has already been made, get the rear wheel off the ground and listen while you rotate the rear wheel.
Dan89FLSTC is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 09:26 PM   #12 (permalink)
Dools103's Avatar
Dools103 wants to know Dino or Syn?
I wonder if we worry as much about noises coming from our spouses as we do our bikes, Just sayin
Dools103 is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 09:53 PM   #13 (permalink)
HotRod
mmcdermott's Avatar
mmcdermott wants to know Dino or Syn?
When there are noises from my bike, there is a logical explanation as to why. As far as my OL, logic doesn't always apply.
mmcdermott is offline   Reply With Quote Quick reply to this message
Old 07-22-2012, 09:56 PM   #14 (permalink)
disregard my advice
Old 07-23-2012, 12:04 AM   #15 (permalink)
Thanks everyone for the advise, I'll lift the bike tomorrow and will confirm if it's the belt or brake pads.
