Easy catalytic converter removal writeup - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 07-24-2012, 01:29 PM   #16 (permalink)
ultra103's Avatar
ultra103 is on a distinguished road
You'll likely enjoy the new sound and more low end torque!
ultra103 is offline   Reply With Quote
Old 08-01-2012, 07:06 PM   #17 (permalink)
TUCCI's Avatar
TUCCI is on a distinguished road
That's what I did....pretty slick huhh............
2011 FLHR ROAD KING
96" motor/50w VR1 in winter-60w VR1 in summer/Jackpot 3.5" mufflers/Catalyst removed/SS Stealth AC/Mustang solo seat with backrest/Santee 14" apes/Road 6 Customs lowering kit/Jagg 10 row oil cooler without thermostat/floorboard extenders/Badlands brake-light kit/Power Commander-5 with modified FM map....
TUCCI is offline   Reply With Quote
Old 08-08-2012, 11:32 PM   #18 (permalink)
dortiz64's Avatar
dortiz64 is on a distinguished road
nice work on the welding
had mine drilled out with a coring bit. Not a thorough as the welding job, but they did get a big section of it straight thru the middle took and it took less than one hour about $75.00. the coring bit is about the diameter of the exhaust pipe entering from the header pipes and is visible from the muffler looking in
2010 Street Glide, 103" Big Bore, 255 cams, Rhinehart 2/1, SERT, HID lights, compression release, de-cored cat, Engine LED lights, fairing lowers, heavy breather, hogtune tweeter pod, boom upgraded fairing speakers, and a few paychecks in chrome doo dats
2009 XR1200 - D&D exhaust, XIEDS, black diamond collection pegs, and grips. Luggage, sissy bar, Harley black LED headlight assembly, mini sport windshield
dortiz64 is offline   Reply With Quote
Old 08-09-2012, 10:05 PM   #19 (permalink)
Arse Hole and Good at it
FL8X's Avatar
FL8X is on a distinguished road
Pretty much the same thing I did about a year and half ago and never had any issues with it. Only I cut mine in half and removed the cat and tig it back together. Just recently swap it out for the power duals and cant really tell any difference in the two. Anyone looking for a head pipe?
2010 SG
PCV
V&H Power Duals
V&H Monster Ovals
SE Stage I Cleaner with K&N Filter
Andrews 48H Cams
Polk Audio MM651
Rockford Fosgate PBR300X2
FL8X is offline   Reply With Quote
Old 08-09-2012, 10:53 PM   #20 (permalink)
TRazzo's Avatar
TRazzo is on a distinguished road
Where do the O2 sensors go in that pipe? On my 2012 they are about where you guys are taking out the cat. So they must have moved the cats and put them in the headers ahead of the union? I might be interested if it would work on my bike.
2008 105th Anniversary FLHX - Traded
2012 Road Glide Ultra Ember Red Sunglo
TRazzo is offline   Reply With Quote
Old 08-09-2012, 11:09 PM   #21 (permalink)
FL8X's Avatar
Should be in the same spot, just before the cat.
2010 SG
PCV
V&H Power Duals
V&H Monster Ovals
Andrews 48H Cams
Polk Audio MM651
Old 08-10-2012, 07:18 AM   #22 (permalink)
scottq60's Avatar
scottq60 is on a distinguished road
Tim...I'm interested! How much?
PM me.
2012 Ultra Limited (purple/flames)
scottq60 is offline   Reply With Quote
Old 08-16-2012, 11:01 AM   #23 (permalink)
Teut is on a distinguished road
Did you use a different map after removing the cat?
If so,is it the same map as for the power duals?
I have a international model flht 2010 and in europ there is no info.
All advice is welkom.
Teut is offline   Reply With Quote
Old 08-16-2012, 01:47 PM   #24 (permalink)
Seasoned and Baked
WideOne's Avatar
WideOne is on a distinguished road
Originally Posted by ultra103 View Post
I wanted to remove the cat from my 2012 Ultra Limited but I didn't want to take the exhaust apart much.
How did a cat get stuck in your exhaust pipe anyway? Seriously, good write -up and pics!
There's an ass for every seat
Mrs. Kate WideOne
2-27-54 ~ 4-28-12
Forever Loved
The Toybox
WideOne is offline   Reply With Quote
Old 08-17-2012, 08:20 AM   #25 (permalink)
FL8X's Avatar
I did use a map for the power dual after I did the cut out, its about the closest thing to it with no problems. I did have it tuned not to long ago to see if I could get some mileage back, and it wasn't too far off. Found out the mileage problem is me, ha, so guess Ill live with that. The best thing about it, beside the sound and a little performance gain, was getting rid of the heat from under the seat.
2010 SG
PCV
V&H Power Duals
V&H Monster Ovals
Andrews 48H Cams
Polk Audio MM651
Old 08-17-2012, 09:57 AM   #26 (permalink)
Retired TMCM(SS)
DoctorDee is on a distinguished road
Do you have to get emissions tested in Arkansas? Here we get tested once the bike is over 5 years old.
DoctorDee is offline   Reply With Quote
Old 08-17-2012, 11:26 AM   #27 (permalink)
Thanks for the info,FL8X.It is a great help in making a decision about the pipes.
Old 08-17-2012, 02:38 PM   #28 (permalink)
Larbaldi's Avatar
Larbaldi is on a distinguished road
Originally Posted by plongson View Post
It's actually where you place the welding ground cable. The correct answer is to clamp it ON THE PIECE THAT IS BEING WELDED and as close as reasonably possible to the weld. Not on the bars, wheels, frame, or engine if working on the pipe but ON THE PIPE, and the current will travel between the two leads and not through bearings or electronics.
" It's actually where you place the welding ground cable. The correct answer is to clamp it ON THE PIECE THAT IS BEING WELDED and as close as reasonably possible to the weld. Not on the bars, wheels, frame, or engine if working on the pipe but ON THE PIPE, and the current will travel between the two leads and not through bearings or electronics."
Hopefully .... I've seen this NOT WORK in several instances ( on a car ) and it the damage was severe .... It's ALWAYS BEST to remove the parts being welded from the vehicle.
Ride Safe ..... Ride Often
2009 FLHTCU ( BLACK, OF COURSE ! )
1992 FLHTCU ( BLACK, OF COURSE ! )
1979 FXEF STROKER ( BLACK, OF COURSE ! )
AMA MEMBER / ABATE MEMBER
Larbaldi is offline   Reply With Quote
Old 10-11-2012, 02:22 PM   #29 (permalink)
ultra103's Avatar
No testing or even vehicle inspections here - nothing.
Old 10-11-2012, 03:52 PM   #30 (permalink)
StreetGlideDoo's Avatar
StreetGlideDoo is on a distinguished road
Thanks for the post...
StreetGlideDoo is offline   Reply With Quote
