06-28-2012, 09:32 PM
Poor man's Stage 1?
I have a 05 FLHRI with a very cool Screamin Eagle air cleaner football cover, however, that is all there is "screamin" about the intake. It has the full size stock plastic back, and an HD paper filter.
I have drilled holes and added pipe to air boxes on diesel trucks to increase air flow before, so it occurred to me, why can't I do that to the bike? Open up the plastic, cut out the bottom, drill holes, whatever, and add a KN filter sized for the stock air cleaner box? Would this give me a sub-$50.00 stage one, or something close? More importantly, would this not work for some reason?
Anyone tried this before? Any thoughts, gentlemen? (and ladies, of course)
06-28-2012, 10:32 PM
Acquisitions
Just remove the whole plastic backing!
 Back in Black
06-29-2012, 06:51 AM
I did exactly what you are talking about to a b2002 FLHRCI Worked perfect. The Dyno tuner told me it flowed every bit as good as a SE
06-29-2012, 09:10 AM
Ironbutt
Has the exhaust been changed? You won't see any real benefits unless you do the full stage one. That means high flow filter, high flow exhaust, and retune.
Current bikes in the stable:
2009 Street Glide
2003 Heritage Softail Classic
06-29-2012, 11:41 AM
its got v&h pro pipe on there already, so if I open it up at the front end as well, I'll need to go see dynodifference for a tune, I'm thinking...
wolf, what exactly did you do? how much of the plastic did you drill or remove?
I think I want to leave something on top and front for rain....
06-29-2012, 07:31 PM
got mine like that...why deprive it of that extra air flow
11-13-2012, 09:42 AM
Is there really any benefit to changing the air cleaner if you never operate at WIDE OPEN throttle?
EARTH is the artist palette, HEAVEN is the painting.
11-13-2012, 10:01 AM
Yes there is.
11-13-2012, 10:03 AM
No not really
The a/c only helps above 4000 rpms. About 4 hp
07 ULTRA
SE 120Rxtra
11-13-2012, 06:18 PM
There ya have it sports fans, a 'yes' and a 'no'. Together they amount to a definite maybe.
Actually stroker's reply may be slightly more correct, at least as far stock motors go.
11-13-2012, 08:16 PM
about the size of it ...yes and urrr no
STAGE 1 96 CI
blue is stock A/C
red is uncorked
07 ULTRA
SE 120Rxtra
11-15-2012, 10:07 AM
If you increase the airflow in, you should increase the airflow out!
11-15-2012, 04:53 PM
 If you let it in it's gotta get out or you're not making any horses.
11-15-2012, 07:02 PM
The Best Me I Can Be
Not only that, but if the old air can't get out then the new air can't get in.
Keep The Change
11-15-2012, 07:26 PM
just because you put a stage 1 breather on dosent mean there is more air going in . there isnt a restriction until 4000 rpms at WOT.
just like putting some aftermarket exhausts on dosent make it breath any better than some stock exhaust.
you disrupt/change the flow and cause it to go lean as well as rich in areas of the map (EFI) when changing the A/C, but the biggest changes will be seen under load at 70 kpa and up.
and on decel.
07 ULTRA
SE 120Rxtra
| Sponsored Links |
