Anyone running the Andrews 57H : V-Twin Forum: Harley Davidson Forums
Old 04-28-2012, 08:58 AM   #1 (permalink)
bglidin is on a distinguished road
I have heard nothing in awhile about this cam it was the talk of the town. I have a Limited ready for a cam and was eyeing the 57H. Did anyone ever post any results?
BGLIDIN
bglidin is offline   Reply With Quote
Old 04-30-2012, 03:27 PM   #2 (permalink)
acbacb is an unknown quantity at this point
Saw a dyno sheet on another forum (HTT) of the 57 in a 110. Nice numbers for a straight up bolt in cam. They are on backorder until June per Gary Wallace of Andrews Products Tech Support via an email inquiry.
I will do my build this coming winter so I should get a hold of one by then. I think I'm just going do a true bolt-in cam (57H), stay at 103 & no headwork. I'm just looking for a little more oomph and a lot less heat. This will save lots o' dollars and I will be happy with the results.
A Wise Man Once Said
"If it has tires or ti+s, sooner or later it's gonna give you trouble."
2012 FLHX Street Glide in Big Blue Pearl
Bone Stock (for now)
acbacb is offline   Reply With Quote
Old 05-02-2012, 05:37 PM   #3 (permalink)
I will wait to see some feedback before doing anything , but this looks like it would hit hard out of the hole and pull to mid 5k range . We will see.
Old 05-03-2012, 09:28 AM   #4 (permalink)
bigbadal's Avatar
bigbadal is on a distinguished road
I have a '94 evo that I will be putting the 57 cam into very soon. I don't have any experience with the twin cams and their clearances for valves, springs and valve stem seals, but for the evo, I was informed that the valve guides needed to be moved down so the seals would not be smashed by the spring collars. Also, the Andrews cam spec sheets say to use larger springs (theirs, of course) and high lift collars. I'm wondering if the 57 for the tc has the same specs as for the evo. I know I'm talking two different engines here, but just some thoughts to throw out.
BTW, the mechanic that always helps me says that the 57, in his opinion, is the best cam for the heavy bikes. He has been trying to talk me into this cam for two years, and we finally located one on the shelf at Andrews. They don't make them anymore for the evos, the 59 has replaced the 57.
Hope the 57's work good in your limited.
bigbadal is offline   Reply With Quote
Old 06-13-2012, 10:59 PM   #5 (permalink)
markmgm's Avatar
markmgm is on a distinguished road
subscribed
Enjoying my 2011 Roadking Classic
Vance and Hines Power Duals,Monster Rounds,Zippers cam chain tensioners,TW222 cams, Feuling lifters, PowerVision.
http://www.youtube.com/watch?v=vmcv4cPZh0s
markmgm is offline   Reply With Quote
Old 06-14-2012, 04:08 PM   #6 (permalink)
Barney Biker is on a distinguished road
The Andrews 57 just came out.
Didn't know they made them for an evo engine.
Barney
Barney Biker is offline   Reply With Quote
Old 06-20-2012, 09:58 PM   #7 (permalink)
cardboard is on a distinguished road
It was to my understanding it was for stroker motors........
2011 Ultra Limited
cardboard is offline   Reply With Quote
Old 06-22-2012, 09:50 AM   #8 (permalink)
57h
Yes 103 and 110. Still looking for dyno sheets in 103 motor just like our Limited 103. Nice bike by the way.
Old 07-26-2012, 03:25 PM   #9 (permalink)
I got my 57 in and will do the build in October. Will post the sheet then.
Old 10-02-2012, 10:49 PM   #10 (permalink)
doug7x is on a distinguished road
Gary from Andrews also recommended the 57h for my '08 96" DWG. Now, I know that I'm quite a bit lighter than the baggers...I'm a little confused....the same cam for a 96" Dyna AND the heavier 103" baggers? Your thoughts, please..
doug7x is offline   Reply With Quote
Old 10-03-2012, 12:17 AM   #11 (permalink)
Barney Fife - Fake Biker
<G Man>'s Avatar
<G Man> will become famous soon enough
The EV57 was a cam for EVO engines, typically used for those bored to 88ci+. It was a hi-lift cam and required springs and collars to be upgraded.
The 57H is a new cam set for Twinkies, 96,103 and 110. It has the same .560 lift which works with stock springs in the TC where anything over .510 was considered "hi-lift" for an EVO.
It looks like if you're keeping stock cr, the 48H will probably give better low end torque (out of the gate). 57H comes on a little later than the 48H but the overall specs are very similar. These cams both work in 2007-current Dynas. These are both chain drive cams.
Be wary of someone selling one cam as "the best for XXX engine". The key is to match the cam to the rest of the build. Compression ratio is probably the most important thing to match correctly as well as considering your riding style.
G Man
'97 FLHPI
80c.i. - EV27 cam - stock pistons - stock heads
SE a/c - Rinehart True Duals - Barnett performance clutch
MM EFI - hi flow injectors - PCIII USB
Tru-Trak stabilizer - customized Corbin seats - beach bars
chrome crap - detachable stuff
<G Man> is offline   Reply With Quote
Old 10-03-2012, 06:42 AM   #12 (permalink)
If you talk to Bob Woods or my HD dealer they are gonna tell you go to with the Woods 555 cam.
2011 Ultra Limited
Old 10-28-2012, 11:06 AM   #13 (permalink)
Neuropac's Avatar
Neuropac is on a distinguished road
Any dyno numbers on the Andrews 57h in a 103 tc
2011 FLTRX vivid blk
2005 BigDog Ridgeback
1982 FXR SuperGlide
Neuropac is offline   Reply With Quote
Old 10-29-2012, 11:30 AM   #14 (permalink)
clayslayer is on a distinguished road
I'd be curious to see a dyno sheet on the 57 would look like. Looks like it's 2* earlier than my TW-555 cams and has .005" more lift. I'd bet a handful of pocket lint that two identical bikes with TW-555 and TW57 cams would be impossible to tell apart.
That being said I'll have to recommend the Woods TW-555 cam cause that's what I have and I need to justify the extra money I spent on it. (FTR I'm pleased as punch with it...)
2010 FLHTK. SE Ventilator w/K&N filter, FuelMoto Jackpot 2-1-2 header, SuperTrapp SE mufflers, Wood TW-555 cams, PC-V . 84hp/104tq. Leaks oil.
2007 CBR600RR. Ohlins FGK forks and TTX36 shock, Zero Gravity DB windscreen, Woodcraft case covers, Vortex sliders and spools, Michelin PP2CT tires, Spongebob keychain. Does not leak oil.
clayslayer is offline   Reply With Quote
Old 10-29-2012, 12:30 PM   #15 (permalink)
strokerjlk's Avatar
Doing acbacb Alan's bike now with the 57.
Power duals and crusher mellows.
Should be strong. It was strong with a little tweaking "bone stock"
77 hp 98 tq
07 ULTRA
SE 120Rxtra
