Anyone running the Andrews 57H - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 11-01-2012, 06:26 AM   #16 (permalink)
monkeybutt's Avatar
monkeybutt is on a distinguished road
Originally Posted by strokerjlk View Post
Doing acbacb Alan's bike now with the 57.
Power duals and crusher mellows.
Should be strong. It was strong with a little tweaking "bone stock"
77 hp 98 tq
Is this going to be just bolt in with stage 1? Very interested in this cam and Kury's new tc-24.
2008 FLSTF
117", cvo 110 heads by Wolfgang, TW68's, HPI 58/62, boarzilla. 138hp/132tq SAE
2012 FLTRX (new baby)
S&S powertune duals, Rinehart 4" slip ons, Kuryakin Mach II AC, 78hp/99tq SAE
monkeybutt is offline   Reply With Quote
Old 11-01-2012, 10:32 PM   #17 (permalink)
strokerjlk's Avatar
yes from stock to stage 2
bolt in, no head work
getting closer
this is what it did in all stock trim 14,000 miles ,with a little tuning
07 ULTRA
SE 120Rxtra
Old 11-06-2012, 05:23 PM   #18 (permalink)
monkeybutt's Avatar
77 hp 98 tq
So you done yet? Not rushing you or anything, but you done yet?
2008 FLSTF
Old 11-06-2012, 07:08 PM   #19 (permalink)
INDEPENDENT 1 is on a distinguished road
Here's a dyno sheet from a customers bike done last week with the 57H on a 2012 FLTRU with Drago's true duals and a TMax. This was just with a canned map put in and the auto adjust had not had a chance to do its thing.
I also put a set of Big Boyz heads on and a .027 HG
Name:	Robert Kilian dyno sheet.jpg
INDEPENDENT 1 is offline   Reply With Quote
Old 11-07-2012, 09:15 AM   #20 (permalink)
strokerjlk's Avatar
not done yet. last pull last night before I lost a sensor was impressive.
bike is tuned,just not tweaked yet. I only got 4 pulls in wot.
it could be all done ,as it has decent timing and fuel as it is.
but it broke 100 hp std. and is 1 1/2 hp away from breaking 100 hp sae.
98/109 sae
101/112 std.
I like it for sure. alan is gonna like it even more.
07 ULTRA
SE 120Rxtra
Old 11-07-2012, 05:19 PM   #21 (permalink)
monkeybutt's Avatar
That sounds impressive for sure. How do you like this cam compared to T-man's torqster555 or the tw555? I know the new Kury cam isn't out yet so can't compare that one. Just curious if there is much difference between these.
2008 FLSTF
Old 11-09-2012, 08:24 AM   #22 (permalink)
Slick03 H-D's Avatar
Slick03 H-D is on a distinguished road
waiting to see the sheet on this one myself..kind of at a crossroads right now between the T-Man 555 torqster and the Andrews 57h and any input is appricated. Also Stroker, how was the 57h as far as valvetrain noise? Did you bump compression and did you use stock pushrods? Dont mean to bombard you with questions but at this point I'm on the fence on which cam to order,,personally I'm using a Dragula 2-1 pipe and H-D Ventilator a/c and one of the new TTS tuners and going to do the cam and looking at the 0.30 Cometic headgaskets for mine and then have Doc Weaver re-tune it.
03 100th anniv silver & black bagger/SOLD IT/MISS IT
2013 110th anniv dark bronze metallic & black bagger.
Andrews 57h cams/.020 off the heads/SE adj pushrods
Drago's Dragula 2 into 1 pipe
H-D Ventilator air cleaner.
TTS tuner/dyno by Doc/98hp & 107tq
CVO adjustable rear shocks
Leather C&C seat
Freedom 8" dark smoked windshield
Streamliner boards/pegs
Nostalgic bag rails and as much chrome as I can find
plus more stuff to come much to my wife's dismay.
Slick03 H-D is offline   Reply With Quote
Old 11-09-2012, 08:57 PM   #23 (permalink)
strokerjlk's Avatar
here is the sheet with the 57 cams.
bolt in cams and exhaust ,thats it. stock heads, you can see where they run out at 5300 rpms,
but 100 tq at 2500 = fun and 100 tq at 5250= 100 hp
a lot of bang for the buck on a new ride.
I haven't done the 555 ?
I rode it today and it feels like a totally diff bike.
07 ULTRA
SE 120Rxtra
Old 11-10-2012, 06:38 AM   #24 (permalink)
Stroker, how is it as far as valvetrain noise? I used an Andrews cam once in my evo about 15 years ago and while it pulled decent, it sounded like the top end was coming apart..that broke me of Andrews at the time but with time comes change...lol
Leather C&C seat
Old 11-10-2012, 08:25 AM   #25 (permalink)
I'm not stroker but the set I installed were as quiet as stock. I ran them under Gaterman lifters set at .063" deep on the intake side and .073" deep on the exhaust side. I wont have the final tune done for another couple of months. The customer had to go back to his job in Alaska.
Looks like you did a nice job on the tune, Jim. Customer should be well satisfied!
Old 11-10-2012, 05:11 PM   #26 (permalink)
Indy, thanks for the info/reply. Pretty well tells me that I'm gonna try the 57h
Leather C&C seat
Old 11-11-2012, 08:04 AM   #27 (permalink)
strokerjlk's Avatar
this one ....on the right side all you hear is the noise from the throttle body.
on the left you can hear a little tick now and then. basically the same little tick ,that you hear on some of these factory 103's.
gatorman lifters first set to .106 it wasent even close. noisy as heck. totally loose....set them to .130 and it's as described above.
the only way I will use these lifters again is if they are supplied by customer ,as these were.
sorry I wasent impressed. it only took seconds (not minutes) for the lifters to bleed off enough to spin. I didnt even have a chance to roll them up on the lobe to bleed them off before they were spinning. actually by the time i spun the lock nut by hand to get it ready to lock down ,they were bleed off.
sounds good and will work fine with these cams. but personally I wont use them in my motor.
07 ULTRA
SE 120Rxtra
Old 11-11-2012, 05:40 PM   #28 (permalink)
semi-retired
FatBobRob's Avatar
FatBobRob is on a distinguished road
Stroker,What lifters do you prefer? I had the Fuelings in my 95" TW21 build for 22k before i sold it,worked well and quiet w/ S&S pushrods.
I can't means I won't!
FatBobRob is offline   Reply With Quote
Old 11-11-2012, 07:47 PM   #29 (permalink)
strokerjlk's Avatar
I have used feuling and they seemed really nice to me.
but I got a buddy that does way more motor work than me,and he hates them. hell I dont know what to use anymore.
I got wood lifters in my bike. they have there own quirks. but they seem to stay pumped up on the big lift cams,once you get them there. had good luck with black opps.
why the hell whoever made the B lifters dosent see the need for them in the aftermarket ,I will never know.
07 ULTRA
SE 120Rxtra
