Another air cleaner/exhaust question - Page 3 : V-Twin Forum: Harley Davidson Forums
Old 11-12-2012, 12:11 PM   #31 (permalink)
0ldhippie's Avatar
0ldhippie wants to know Dino or Syn?
While the CAT does make heat and break up sound waves it doesn't restrict exhaust flow on a stock/near stock bike. I have not heard of a dyno test showing any gain removing the cat. If you open the intake with a A/C and/or the exhaust with slip-ons/header you need to get a tune/tuner.
Retired and living off the interest on the money I owe.
0ldhippie is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 12:40 PM   #32 (permalink)
mistert wants to know Dino or Syn?
Thanks Slick, I was afraid of the stock ECM not having the range capabilities...I'll go with a PC V or something on that order..did you remove the guts from the cat or change it out?
Thanks to you Old hippie, a couple of my buds are H-D techs and they said pretty much the same thing...change the slip-ons and be just fine, change the A/C and a tuner is needed. Just wondered if anybody tried to "short-cut" the tuner part...Oh well, what's another couple hundred...
mistert is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 12:49 PM   #33 (permalink)
baggerman11's Avatar
baggerman11 wants to know Dino or Syn?
get rid of the cats, it'll run cooler, give you more flow. get a tuner(power commander if you can afford it), set of slip ons, new air filter and you'll be fine. you'll have better performance and
bike will run like it's suppose too. they should be tuned that way from the factory instead of being delivered all leaned out and sounding like sewing machines. just my 2 cents worth
Old Fart Living the Dream
baggerman11 is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 03:08 PM   #34 (permalink)
Just a kid at heart
wydeglyde's Avatar
wydeglyde wants to know Dino or Syn?
The stock ECM will adjust for an air cleaner change, although it will maintain the target air mixture which everyone knows is quite lean. You can subsequently add slip ons and again the ECM will adjust.
If you want to richen it up a bit and you have plans for further mods down the road you should consider a tuner, but don't forget to look at the auto tuning systems which will require no dyno time.
Stay away from the H-D Download. Most people think it adds fuel, but this is incorrect; Harley cannot go beyond the mandated EPA levels. Instead the download removes timing to prevent pinging. Your bike feels much better because you probably added the download at the same time as the AC and slip-ons. If you did the download on a stock bike you would lose performance.
I have chased power on my last few bikes to the point where many other changes became necessary and the bike was actually less fun to ride (day to day). My 05 RG had easily over 50 dyno runs (more than one shop) and still didn't run the way it should have.
On my 2012 I am going to try and stick to the stock exhaust with an air cleaner and auto tuning fuel system.
12 Road Glide Custom
wydeglyde is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 03:35 PM   #35 (permalink)
Slick03 H-D's Avatar
Slick03 H-D wants to know Dino or Syn?
Yeah, the pipes you can get away with, once you change the air cleaner you've moved beyond the peramiters that the stock ecm can compensate for..
2013 110th anniv dark bronze metallic & black bagger.
107 motor, heads by V Twin Perf. T-Man 625 cams
Drago's Dragula 1, 2 into 1 pipe with 2.55 baffle
H-D Ventilator air cleaner, Dyno by Doc/115hp & 120tq
CVO adjustable rear shocks
Leather C&C seat
Freedom 8" dark smoked windshield
Painted inner fairing & Fat Boy frt fender
Streamliner boards/pegs
Nostalgic bag rails
10" Yaffe mini apes
More to come much to my wife's dismay
Slick03 H-D is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 03:37 PM   #36 (permalink)
merry old soul
Road King Cole's Avatar
Road King Cole is still riding a stock bike Road King Cole is still riding a stock bike
Really, the cat does not cause any exhaust restriction?
I just find that hard to believe...
rkc
Road King Cole is offline   Reply With Quote Quick reply to this message
Old 11-12-2012, 10:40 PM   #37 (permalink)
I'm with you on that one RKC..cant see it.
Leather C&C seat
Nostalgic bag rails
10" Yaffe mini apes
Old 11-12-2012, 11:19 PM   #38 (permalink)
dortiz64's Avatar
dortiz64 wants to know Dino or Syn?
air cleaner and slip on
my suggestion would be the following: skip the download, tuner etc...and go with a XIED for about $100 this little gadget lowers your AFR to 13.8 from stock 14.6 in lower speeds cruising (city traffic) when you need a little more fuel.....instead of getting a stage 1 air cleaner kit, buy you the stock fit K&N air filter for the stock air filter housing....and now get you a set of slip-ons. This is for the man on a budget..and will keep you from the lean situation...(which is probably a hyped up situation created by the dealers to scare you into buying tuners and over priced dyno....(don't ask me how i know). I am not suggesting defeating EPA smog devices but is not a secret that a simple cement coring bit about 12 inches long has been used to core thru the honeycombed construction of the catalytic converter....and to those who think it does not obstruct exhaust or increase temperatures I would suggest you remove your rear muffler and take a good look at them...the harley stock header is a good piece and if you do change this you will need a tuner and dyno to properly adjust the bike. Keep things simple and cheap....XIED, K&N stock fit replacement air filter, and slip-on.
2014 CVO Limited, Vance Hines, SERT
2015 Dyna Low Rider
dortiz64 is offline   Reply With Quote Quick reply to this message
Old 11-13-2012, 01:28 AM   #39 (permalink)
tekman's Avatar
tekman wants to know Dino or Syn?
if you're just doing stage 1 is it worth getting the auto tune with pc5?
Sent from my SCH-I535
--Ian | Tucson, AZ
--2013 Street Glide
--www.biker-glasses.com
tekman is offline   Reply With Quote Quick reply to this message
Old 11-14-2012, 09:44 PM   #40 (permalink)
dortiz64's Avatar
no
I would not sink my hard earned money on that...if you have a late model EFI model. if you want to have peace of mind get the $159 download from your dealer, or the XIED. I have an XR1200 and I have the High flow air filter, and slip on exhaust and XIED, 10,000 miles and not a bit of a problem....i sank so much money on my SERT, DYNO and miscellaneous stuff on my Streetglide that i promised myself not to do that on any subsequent bike...but this is just my opinion. Read about the XIED...its low price and adds fuel to AFR when you need it in city traffic, cruising speeds etc....
2015 Dyna Low Rider
Old 11-14-2012, 10:01 PM   #41 (permalink)
tekman's Avatar
I'm already getting the pcV so was wondering if I saw an auto-tune used for sale is it worth picking up.
--Ian | Tucson, AZ
--2013 Street Glide
Old 11-19-2012, 05:51 PM   #42 (permalink)
zackt wants to know Dino or Syn?
good options
I recently installed a TTS master tune, Bassani megaphones and a Arlen Ness big sucker. It made a big difference in throttle response and it sounds amazing. So that is an option I would recommend to any one interested in a stage 1. I got all my parts through a new site that is very helpful, great prices and and I got free shipping.http://www.uscycleonline.com
zackt is offline   Reply With Quote Quick reply to this message
