From power duals to 2-1 ( D&D Fat Cat )? : V-Twin Forum: Harley Davidson Forums
Old 11-29-2011, 05:49 PM   #1 (permalink)
markmgm's Avatar
markmgm wants to know Dino or Syn?
Question From power duals to 2-1 ( D&D Fat Cat )?
Just wanted to get an idea of what rider(s) might have noticed
over all, when if if you have changed from a dual/power dual exhaust
on your bagger to a D&D fat cat....
It's cold and snow and such, and too much time to think about
bike stuff.... oh- no..... ( Mr. Bill )- thinks he may want to
change the pipes for Spring.
Thanks,
Mark
markmgm is offline   Reply With Quote Quick reply to this message
Old 11-29-2011, 06:14 PM   #2 (permalink)
hoghawler's Avatar
hoghawler wants to know Dino or Syn?
markmgm
I've had good results from the Fat cat. I normally try to use the quiet baffle version as the standard baffle has a much sharper tone. Either baffle performs well when properly tuned. Any 2-1 pipe should give you gains in low and midrange. Supertrapp is another good choice.
hoghawler is offline   Reply With Quote Quick reply to this message
Old 11-29-2011, 06:42 PM   #3 (permalink)
grof wants to know Dino or Syn?
great pipe and performance, it's loud if you can't stand bark try something else, I like it.
better than D&D is thunderheader best sounding pipes but look is weird and quality is kind of cheap. (my brother has it , I went with D&D no regret )
grof is offline   Reply With Quote Quick reply to this message
Old 11-30-2011, 05:15 AM   #4 (permalink)
Mike02's Avatar
Mike02 wants to know where he is and how he got here
Go with the vance ProPipe.... looks awesome and sounds evern better..
Performance will also improve
Mike02 is offline   Reply With Quote Quick reply to this message
Old 11-30-2011, 05:34 AM   #5 (permalink)
PAULIE61's Avatar
PAULIE61 wants to know Dino or Syn?
For a touring bike I would think about the Supertrapp Supermeg.
Can be adjusted for sound levels and the power gain is very good.
Quality and fit are excellent
http://www.v-twinforum.com/forums/attachment.php?attachmentid=40225&d=1176768702
PAULIE61 is offline   Reply With Quote Quick reply to this message
Old 11-30-2011, 05:40 AM   #6 (permalink)
strokerjlk's Avatar
Thanks,
Mark
Hard to say without knowing what your swapping the exhaust on.
stage 1 or 2 on a 96 ci up to some 107's you will see some gains in lower rpms
and a little more power under the curve.
bigger ci and you are going to see the fatcat choke it down,and the power duals make more peak hp/tq.
07 ULTRA
AMRA
SE 218
DR 218
Old 12-02-2011, 01:15 PM   #7 (permalink)
tgspencer56 wants to know Dino or Syn?
Can't beat the D&D with the performance baffle.
tgspencer56 is offline   Reply With Quote Quick reply to this message
Old 12-02-2011, 06:38 PM   #8 (permalink)
gogogadgetbiker's Avatar
gogogadgetbiker wants to know Dino or Syn?
I was on the phone with Dragos today discussing this exact thing for my 120R build. He said although there are a few horsepower to gain from the 2-1 your not likely to notice it in the butt dyno.
Basically advised me that if I like the way true duals sound, stick with that.
Bill,
2006 King with some stuff.....
www.choppedbaggers.com
gogogadgetbiker is offline   Reply With Quote Quick reply to this message
Old 12-02-2011, 08:05 PM   #9 (permalink)
markmgm's Avatar
still on fence
I like the look of true duals / power duals ........
I would not mind even more torque under the curve LOL
Thanks,
Mark
Old 12-02-2011, 09:14 PM   #10 (permalink)
Enjoying a great Ride.
jeffsglide's Avatar
jeffsglide wants to know Dino or Syn?
D&D 2n1 boss fat cat for looks, and sound, plus power gains there no better pipe on the market period. There pricey but worth every $.
jeffsglide is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 04:27 PM   #11 (permalink)
petew's Avatar
petew wants to know Dino or Syn?
Sooo has anyone gone from the 2-1-2 to a 2-1 anything and how did that change feel?
2011 FLTRX 103" Stage IV, HoleShot Choppers LED Lighting, SE 259E Cams, SE Super Tuner, SE Heavy Breather AC, SE CNC heads, SE 58MM Throttlebody, Vance&Hines Power Duals, and V&H Hi-Output Slip-ons, Renegade Racine Contrast Cut 21x3.5 17x6.25/ Avon 120/70x21" Avon 200/55x17" Dyno Tuned by HDHD 117HP 111TQ
petew is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 05:58 PM   #12 (permalink)
tj316 wants to know Dino or Syn?
I've ran true duals , 2-1-2 and 2-1 , 2-1 you get more low end torgue and the bike gets up and goes , I'm running a Bassani Road Rage II , had a guy at the shop do same exact build as mine with the D & D , the curves were very similar , if I was to buy another 2-1 I'd buy Drago's Dragula , it looks good turns impressive numbers at at $650 it's priced right and sounds good
2011 FLTRX 120ST , Cycle-Rama Heads , CR-630i cams , TTS Master Tuner , Drago 2-1 pipe , Hawg Wired amp/Hertz speakers , Dakota Digital Gauges , Ohlins #6 shocks & 30mm fork cartridges , Lyndall Rotors , BR Handlebars ,Jagg fan assited oil cooler and so much more
tj316 is offline   Reply With Quote Quick reply to this message
Old 12-05-2011, 02:43 AM   #13 (permalink)
C-Cat wants to know Dino or Syn?
I've seen a tq dip in the midrange with the FC on Baggers. I run D&D on my Dyna and like every thing about the quality, fit, perf., however just can't over look the bagger TQ dip. My good friend owns a superflow dyno and he's been using V&H PP HO on all of is 103 builds and the VH PP HO out performs the FC hands down.on a bagger, just doesn't lok as good IMO. I'm going to run VH Power Duals with Crusher mufflers on a 107 (2011 RGC) I'm doing this winter. Not worried about #'s, just like the look and sound, not to mention it should'nt be a slouch in the performance dept.
124 ci. 07 Streetbob
107ci. 2011 RGC
C-Cat is offline   Reply With Quote Quick reply to this message
Old 12-05-2011, 10:08 AM   #14 (permalink)
Sage Counsel's Avatar
Sage Counsel wants to know Dino or Syn?
2 into 1 will get better torque across the rpm range, generally speaking. Good for a touring bike.
See
and
FLTRXSE 2012
Sage Counsel is offline   Reply With Quote Quick reply to this message
