2002 Road King Cruise control failure : V-Twin Forum: Harley Davidson Forums
Old 10-21-2011, 07:17 PM   #1 (permalink)
RustyG wants to know Dino or Syn?
Today the Cruise control on my 2002 Road King (FLHRCI) went kaput. Seems like the stepper motor is inoperative.
All functions work except it fails to keep constant speed. I swapped the control module with another one I have and the symptom stayed with the control module.
Tried ordering another via the internet and was met with rebuffs everywhere. Seems like Harley has stopped distribution of cruise control parts for early touring models.
The part in question is 70955-98B - Control module. It is also part of Cruise control kit 77183-02 also no where to be found.
I have been unable to find anywhere in the universe a place that sells 70955-98B.
One thread I found said that 70989-98B is an acceptable substitute but it also is no where to be found. Also how can I confirm this?
Has anyone gone through this scenario? If yes, what can be done to get my Road King cruising again?
Regards,
John
Everything is JMHO. Accuracy is not assured.
Originally Posted by Mark Twain
The more I know about people the better I like my dog. -
2007 VRSCX 0461 / 1400
2003 VRSCA Gone but not forgotten.
2002 Road King Classic
RustyG is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 07:36 PM   #2 (permalink)
Harleypingman wants to know Dino or Syn?
Have you used your local dealer's parts counter and asked them to do a "part locator" search nationally/internationally using HDNet?
Carl
CMA, Crossties Chapter (GA)
IBA 26580
2004 FLHTPX
Harleypingman is offline   Reply With Quote Quick reply to this message
Old 10-21-2011, 07:54 PM   #3 (permalink)
Carl
Carl,
Thanks for the quick reply.
That's tomorrows project but other people on the forums I have perused have tried this avenue and failed.
About the only thing I can hope for is a suitable substitute.
About a year ago I purchased one of the kits (77183-02), which has now been obsoleted,for another project which is why I was able to swap the bad one out and determine the module is bad. Unfortunately I need the good one for another bike.
Regards,
John
Old 10-22-2011, 03:07 AM   #4 (permalink)
Biffo wants to know Dino or Syn?
This maybe worth a try .... i thought i had a 'stepper' problem but traced it to the cable module on the headstock, this sits just behind your throttle cables, you got two wires which activate this device, simply unplug it, tape them up and hey presto, the cruise control works reliably again - you can still switch the system off by tapping your front brake but not by rolling of the throttle so be aware.
Good luck pal.
Biffo is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 03:22 AM   #5 (permalink)
srvsgr8t wants to know Dino or Syn?
70989-98c
http://www.kutterharleyonline.com/product/70989-98C
srvsgr8t is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 03:39 AM   #6 (permalink)
70955-98
http://www.ebay.com/itm/1999-Harley-...torcycles_Part
Old 10-22-2011, 03:40 AM   #7 (permalink)
or this page
http://motors.shop.ebay.com/i.html?_...Cruise+control
Old 10-22-2011, 07:20 PM   #8 (permalink)
Good luck pal.
Thanks Biffo,. The thing you are talking about is called a "Roll Out" switch here in the states. I thought of that also but the disconnecting the wires did not resolve the issue.
Regards,
John
Old 10-22-2011, 07:27 PM   #9 (permalink)
Thanks for all the suggestions guys. I have resolved the issue thanks to a bird dogging parts guy at Gator Harley in Leesburg Florida.
He managed to find a "Almost substitute" and it does work. They even had two in stock. Installed it today. It is PN# 70989-98C. It is the module only.
The original PN# (70955-98B) included the cable that attaches the module to the throttle body. The substitute does not have this cable. I do not know what I would do if I ever need a cable since there is no part number for it.
Again, Thanks for all the suggestions, links and comments.
Regards,
John
Old 01-18-2013, 12:57 AM   #10 (permalink)
Ashleigh wants to know Dino or Syn?
I know this is kind of an old post but I thought I would post this I case anyone ever needs it.
The cable you are referring to is called a stepper cable. Part number 56372-98 would most likely work. I called Harley he said he doubts they can get it but when I gave him the part number he said it could be ordered and would be about $40 CDN (there may be a revised part number but he didn't say). I found it in an old cruise control retrofit instruction guide on the Harley website for the 1996-1999 Road Kings
Ashleigh is offline   Reply With Quote Quick reply to this message
