REAR Cylinder not firing : V-Twin Forum: Harley Davidson Forums
Old 10-03-2011, 11:20 AM   #1 (permalink)
xtremehd is on a distinguished road
Went riding and went thru city of PA and stp and go traffic and all of a sudden my rear cylinder was not firing properly, Was running on the front cyl. I swapped out the plugs and changed spark plug wires and also replaced the coil and still the same rear not firing. Could use some help guys would really appreciate it allot.
Harley Dave
xtremehd is offline   Reply With Quote
Old 10-03-2011, 12:35 PM   #2 (permalink)
Maddoghd is on a distinguished road
What year and model
Everything is legal until you get caught!
Maddoghd is offline   Reply With Quote
Old 10-03-2011, 01:38 PM   #3 (permalink)
Indianspringsaz's Avatar
Indianspringsaz is on a distinguished road
07 and newer sitting at idle, this will happen. Parade mode.
07 Road King Standard
GMR 107 with Andrews 54 cams
D&D Fat Cat, CNC Ported Heads
Big Sucker, TTS Mastertune
SERT 107/115
Arizona AMSOIL connection
Indianspringsaz is offline   Reply With Quote
Old 10-03-2011, 02:02 PM   #4 (permalink)
Icarus_'s Avatar
Icarus_ is on a distinguished road
I've never heard of this. Does this apply to all models?
Icarus_ is offline   Reply With Quote
Old 10-03-2011, 02:44 PM   #5 (permalink)
Not sure if its all models. But it is a fact. It happened quite a bit to me here in Phoenix before I did all the upgrades. I still have it activated but hasnt went on in a while. It can be turned on and off with the SERT or TTS.
SERT 107/115
Old 10-03-2011, 02:47 PM   #6 (permalink)
DURWOOD's Avatar
DURWOOD is on a distinguished road
I don't think they started doing this till they went throttle by wire.
Turn the ignition switch on and roll the throttle forward and it will disable this function..
2011 Road glide Ultra 103
V&H Power Duals
Rush 2" Slip on's
SE A/C
SE 204's
Tune by Stroker
John 3:16
DURWOOD is offline   Reply With Quote
Old 10-03-2011, 03:33 PM   #7 (permalink)
another guy said that it could be the ECM took a dump.
Old 10-03-2011, 03:33 PM   #8 (permalink)
2007 Street Glide
Old 10-03-2011, 04:55 PM   #9 (permalink)
There you go. My 07 has it. I think it was the first year. Get a stage one and have it tuned. It will run much cooler.
SERT 107/115
Old 10-04-2011, 10:30 AM   #10 (permalink)
09flhrjw is on a distinguished road
my 09 roadking does this but i can adjust it by rolling the throttle fwd with the ignition on and watching the cruise light red is off green is on. it only controls the idle
though, supposedly it keeps the heat off the passenger by shutting down the rear cylinder. not sure if you can turn it on and off without going to delaer on the 07 model though , best of luck to you. it should go away once it cools down
09flhrjw is offline   Reply With Quote
Old 10-04-2011, 10:30 AM   #11 (permalink)
my 09 roadking does this but i can adjust it by rolling the throttle fwd with the ignition on and watching the cruise light red is off green is on. it only controls the idle though, supposedly it keeps the heat off the passenger by shutting down the rear cylinder. not sure if you can turn it on and off without going to delaer on the 07 model though , best of luck to you. it should go away once it cools down
[/QUOTE]
Old 10-04-2011, 11:33 AM   #12 (permalink)
03 Roadking's Avatar
03 Roadking is on a distinguished road
It can only be turned off by the dealer on the 07 model. It should have started firing again once you opened the throttle.
2009 FLTRSE3
USAF Retired
03 Roadking is offline   Reply With Quote
Old 10-04-2011, 01:22 PM   #13 (permalink)
nortster is on a distinguished road
My first panhead; a 57 fl wuz firing only on the front cylinder.
As an ignorant teen, I wuz too dumb to notice until someone fixed it for me.
It was an ignition problem.
My 05 Sporty often fires on only the front cylinder till it warms up or goes a couple miles.
Dan Quayle does my spellchecking
nortster is offline   Reply With Quote
Old 10-04-2011, 02:01 PM   #14 (permalink)
I attempted to do that but it would not fire at all, I rode it from PA to NJ at about 50 MPH, couldn't go no faster and really didn't want nothing else to happen at that point, I think its the PC III that I have installed or the ECM might have taken a dump.
HD Dave
Old 10-04-2011, 02:42 PM   #15 (permalink)
Thread Ender
Pikeslayer's Avatar
If it is an ignition problem, and that cylinder was getting fuel the whole time from PA to NJ you may have washed down the cylinder. Time for a big bore kit.
2007 Street Glide
