Can't get slip on exhaust off.... : V-Twin Forum: Harley Davidson Forums
Old 09-12-2011, 03:00 PM   #1 (permalink)
Cruisin' SoCal
SoCal harley's Avatar
SoCal harley wants to know Dino or Syn?
I got Rinehart slip ons, want to take them off, got the bracket off and the manual says twist and pull exhaust off. Well I am pulling and it only budged about half inch. It moves back and forth like it wants to come off, but it wont freaking come off.
Any help would be greatly appreciated.
2011 Street Glide - 500 miles
2006 Night Train - 22,000 miles
2002 Ford F150 - 88,000 miles
2001 Ford Expedition - 90,000 miles
1989 Ford Mustang GT 5.0 - 121,000 miles
SoCal harley is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 03:18 PM   #2 (permalink)
ultrat's Avatar
ultrat wants to know Dino or Syn?
Oh they will come off I have had to heat mine w/ map gas tourch or a butane one ..don;t get crome so hot as to turn it yellow....I also use bracket as leverage leave one bolt in one out...good luck ';';'
ultrat is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 03:30 PM   #3 (permalink)
plumpbiker's Avatar
plumpbiker wants to know Dino or Syn?
I've run into this several times. Ain't no fun at all. I just keep working it back and forth, in and out until it breaks free. They're such a snug fit that the tiniest amount of crap between them acts like cement. Good luck. Maybe somebody will give you a better answer.
plumpbiker is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 04:14 PM   #4 (permalink)
cata5803's Avatar
cata5803 wants to know Dino or Syn?
Have to work it , I've even used a 2x4 and put it at the brackets where you bolt under baggs. Then some sort of never seize when installing..
2008 FLHTI Standard (29 of 200)
cata5803 is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 04:19 PM   #5 (permalink)
johnmon's Avatar
johnmon wants to know Dino or Syn?
Rubber mallet!
____________________
07 Street Bob
Screaming Eagle Heavy Breather, V/H Big Radius, H/D Race Tuner
Street Slammers (Drag Bars).
http://s106.photobucket.com/albums/m...t=Nobadges.jpg
johnmon is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 04:43 PM   #6 (permalink)
Dyna John wants to know Dino or Syn?
Are those the Harley extended bags or something else?
Dyna John is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 04:53 PM   #7 (permalink)
plumpbiker's Avatar
Originally Posted by johnmon View Post
Rubber mallet!
Yep. Done that before!
Old 09-12-2011, 10:23 PM   #8 (permalink)
Barney Biker wants to know Dino or Syn?
Spray a little WD-40 or so into the front between the muffler and the pipe.
Let it soak for a while and work with the pipe some more.
It will come off but may take a little more persuasion.
Barney
Barney Biker is offline   Reply With Quote Quick reply to this message
Old 09-12-2011, 10:43 PM   #9 (permalink)
twalte's Avatar
twalte wants to know Dino or Syn?
This anti seize tip really worked for me...wish i had known on the original install.
First time i took them off, took forever just wiggling and pulling. I put anti seize on last time, and they came off within 30 seconds this weekend.
TWalte
'09 Road Glide
Red Hot Sunglo
c&c solo seat,
V&H Monster Ovals
Harley Oil Cooler
twalte is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 07:19 AM   #10 (permalink)
Bon temps rouler!
mfalba's Avatar
mfalba wants to know Dino or Syn?
WD40 and then just keep wiggling'.
When you put 'em back together put a little coat of anti-seize where they overlap and next time it won't be so hard to get 'em off!
Mike
2002 FLHPI: SE Cast 95" Flat tops, Heads by Bean, Stock TB Bored by Hillside, Andrews TW21, Supertrapp SuperMeg 20 disks w/endcap, Jagg Oil Cooler, Glide Pro Stabilizing System, Seat by Mean City, Windshield by Cee-Bailey.
2006 FLSTCI: SE Cast 95" 10.25:1, Super Stock Heads by Dan Baisley, 50mm SE TB, Woods TW6G, D&D Fat Cat with QB, Jagg Oil Cooler, Seat by Mean City, Windshield by Cee-Bailey
mfalba is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 07:54 AM   #11 (permalink)
bull wants to know Dino or Syn?
A rubber strap wrench can help. almost like unscrewing them from the headpipes. Twist back and forth and pull. I've fought with them for an hour or so before. WD-40 or other lube helps.
bull
bull is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 08:33 AM   #12 (permalink)
pappy42 wants to know Dino or Syn?
PB Blaster works good.
I'd be real cautious about using an open flame around any gasoline powered vehicle. I use a heat gun.
pappy42 is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 08:55 AM   #13 (permalink)
ultrat's Avatar
Your rite there ... heat gun..... be safe ';';';
Old 09-13-2011, 09:21 AM   #14 (permalink)
Chart wants to know Dino or Syn?
lube oil, and use a scrap 2x4 as a drift on the front of the slipon, hitting the board with a hammer, while someone else pulls off the muffler.
really like the never sieze idea. Will do next time.
Chart is offline   Reply With Quote Quick reply to this message
Old 09-13-2011, 09:37 AM   #15 (permalink)
ditchcrusher wants to know Dino or Syn?
Dawn dish soap works well for lube also. Use just like WD40.
DC
ditchcrusher is offline   Reply With Quote Quick reply to this message
