Road King sways back and forth : V-Twin Forum: Harley Davidson Forums
Old 03-27-2011, 01:48 PM   #1 (permalink)
Trip wants to know Dino or Syn?
My 99 RK sways back and forth going down the road around 50 MPH and up. It is like a gyro affect. I'll be going down the road and it will go to the left then right then left. Not extreme like it's going to take me off the road or anything. I put 95 10 spoke mags on it to do away with the wire wheels. It was OK for a long time and now it is doing the snake thing. I have been reading on here and I may need to get it aligned. Any suggestions?
Trip is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 02:48 PM   #2 (permalink)
LowRiderCustom wants to know Dino or Syn?
If the alignment is off that will cause the bike to sway.
LowRiderCustom is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 02:50 PM   #3 (permalink)
Coolmaker's Avatar
Coolmaker wants to know Dino or Syn?
Time to check the swing arm bushings....
Coolmaker is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 02:50 PM   #4 (permalink)
93-331-29PSI's Avatar
93-331-29PSI wants to know Dino or Syn?
what kind of tires front and rear? Radial or Bias?
'12 Candy Colbalt Twilight Blue FLTRXSE
2008 Heritage - Sold
2009 Road Glide - Sold
93-331-29PSI is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 03:09 PM   #5 (permalink)
I had the cleveblocks replaced @83,000. Helped some but still sways. I run the Dunlop standard tires for the RK. They were put on @80,000. 5000 miles on them so I think they are OK. Dealer thought that too. Wheel bearings are new, I had them put in when I changed to the mag wheels. Rear brake rotor is good. New belt installed @76,000.
Old 03-27-2011, 06:11 PM   #6 (permalink)
wurkenman's Avatar
wurkenman wants to know Dino or Syn?
That is your problem. Dunlops suck. Get a set of Avons or Mettzlers. I run the Avons and I will guarantee if you change your problem with tracking will disappear.
Pull the wick tight and hang on!! S&S 107.
AKA Terry
wurkenman is offline   Reply With Quote Quick reply to this message
Old 03-27-2011, 08:36 PM   #7 (permalink)
NOT_A_CVO wants to know Dino or Syn?
just sayn
NOT_A_CVO is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 03:42 PM   #8 (permalink)
OK, but why would they do it all of the sudden? I'll keep it in mind. Thanks Ride Hard
Old 03-28-2011, 03:45 PM   #9 (permalink)
NJ Rider's Avatar
NJ Rider wants to know Dino or Syn?
Make sure your tire pressures are correct. An alignment wouldn't hurt.
NJ Rider is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 03:52 PM   #10 (permalink)
boscoe wants to know Dino or Syn?
Steering head bearings? Frame? Swing arm or tires are my best bets, though.
boscoe is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 04:17 PM   #11 (permalink)
Ok again thanks for the info. I will take it all into account. I used to have a sporty that I put WWW Avons on and I did love them. Got to have WWW in the King. Doing searches now, any suggestions for a good deal on Avon WWW for the King? Ride Hard
Old 03-28-2011, 05:30 PM   #12 (permalink)
Nitram_b4's Avatar
denis kirk is the best place for tires
Nitram_b4 is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 09:03 PM   #13 (permalink)
wurkenman's Avatar
Check here. Usually good pricing.
http://www.shadetreepowersports.com/
AKA Terry
Old 03-28-2011, 09:36 PM   #14 (permalink)
I'm Your Huckleberry
Mr Cujo's Avatar
Mr Cujo wants to know Dino or Syn?
Ditto on tire pressure ...3-5 pounds off is enough to be 10%-15% low and this will cause all kinds of weird stuff...especially at moderate to low speeds.
The other stuff might also be a problem, but I'd check tire pressure first.
Cujo's Blog- CLICKY
'07 Ultra -> Covington, Ga.
Mr Cujo is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 10:06 PM   #15 (permalink)
pidge wants to know Dino or Syn?
I have to ask , is this a new road you rode on when this happened?.Some roads will have a crown that can make your bike feel like it's behaving on it's own.Just a thought.
pidge is offline   Reply With Quote Quick reply to this message
