Erratic Idle : V-Twin Forum: Harley Davidson Forums
Old 11-01-2010, 08:59 PM   #1 (permalink)
GAZRNR's Avatar
GAZRNR wants to know Dino or Syn?
Erratic Idle
I need your help. I have an 09 RG with Rinehart slip on mufflers, SE air filter kit and was race tuned when I got it a year ago. About 2 months ago it started with an erratic idle once warmed up. It would run at 1000 the jump up to 1200, then drop to 950, the 1000 then 1200...bike rides/runs great just off on the idle. I recently installed TW6-6 cams, PCV & autotune and it idles on the same cycle but it is way rich now. I'm seeing 11-12 AFR on the front cylinder and 12 AFR on the rear cylinder. The bike runs great on the road but the idle now must be corrected. I have 7400 total miles on the bike.
Could this be a bad TMAP sensor or bad temp sensor in the head? I can't be the only person to have this happen and need your help with the fix. Thanks in advance.
Rusty
GAZRNR is offline   Reply With Quote Quick reply to this message
Old 11-01-2010, 11:16 PM   #2 (permalink)
WFO
mtrhead269's Avatar
mtrhead269 wants to know Dino or Syn?
did you change the Map when you changed cams? A DTC's stored?
mtrhead269 is offline   Reply With Quote Quick reply to this message
Old 11-02-2010, 07:20 PM   #3 (permalink)
GAZRNR's Avatar
Thanks, Yes they loaded a map for me to work from.Tonight I reset the AFR on the 0 idle cell for each cylinder. They are both now at 13.5 on idle and all is good.
