Clutch adjustment on side stand : V-Twin Forum: Harley Davidson Forums
Old 09-13-2010, 11:56 PM   #1 (permalink)
War Eagle wants to know Dino or Syn?
The manual says to set the bike upright and level before removing the derby cover for clutch pack adjustment.
Since I don't have a lift or center stand, I was wondering if I can adjust my clutch pack with the bike on the side stand without dumping primary fluid or other issues.
What do y'all think?
David
2008 Electra Glide FLHTP - Brilliant Silver
War Eagle is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 12:41 AM   #2 (permalink)
I'm Paid Up...
DR_DEUCE wants to know Dino or Syn?
If it was properly filled, I'll bet that you wont loose any fluid.
ANY TAKERS??
Just so you don't do the adjustment twice.....turn in till "lightly seated" means LIGHTLY SEATED.
DR_DEUCE is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 01:14 AM   #3 (permalink)
'07 Roid King
CheezyRider's Avatar
CheezyRider wants to know Dino or Syn?
Hopefully you won't lose any fluid (you shouldn't but it might be close), just in case, put a 2 x 4 under your kickstand before you pull the cover.
If you're workin' on hard, flat ground, the lean angle is plenty and there's no chance of the bike fallin' over to the right...
I don't care if you lick windows,
take the special bus
or sometimes pee on yourself....
you hang in there sunshine,
you're friggin' special!
CheezyRider
CheezyRider is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 01:40 AM   #4 (permalink)
Zwiehund's Avatar
Zwiehund wants to know Dino or Syn?
Generally speakin, the inside the primary clutch adjustment comes with the 5k service, so it aught to be empty when you do it. Adjustments between 5k's shouldnt be necessary, but can be accomplished at the middle nut without bothering with the primary adjustment.
2004 FLHTCI with Khromewerks Mufflers, Fullsac headers, Stage I Download, Dobeck TFI, Big Sucker, Saddlemen Gel Seat, Windvest Windshield, Cruise, HD Stainless Pullbacks, Throttle-Up Touring Stabilizer, Andrews 21N Cams, Herko Hydraulic Tensioner Upgrade Kit, Hogtunes Sound.
A perfection of means, and confusion of aims, seems to be our main problem.
Albert Einstein
Zwiehund is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 08:10 AM   #5 (permalink)
sportsterleroy wants to know Dino or Syn?
I have one of these and works great for clutch adjustments and refilling the primary.
http://www.lean-right.com/
sportsterleroy is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 08:16 AM   #6 (permalink)
bcomes's Avatar
bcomes wants to know Dino or Syn?
Black Jack
This is one of the best $100 dollars (it was $100 when I bought mine several years ago) I've spent on my bike. I like it better than the traditional lifts because it doesn't block access to the drain plugs and you don't have to lean over it where the traditional lifts stick out on one side. It's plenty stable for jobs such as changing a tire. It's surprisingly stable. I use mine on the concrete floor without a front wheel block.
The Greg Smith Equipment link below (they don't pay the shipping - shipping is free from JCWhitney) has a YouTube movie showing the various frame adapter pieces that come with it.
http://www.gregsmithequipment.com/Bl...000-p/tpbj.htm
If you plan to continue to do some of your own service, you'll never regret investing in one of these.
bcomes is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 08:46 AM   #7 (permalink)
HDSG wants to know Dino or Syn?
You will not lose a drop. While the derby cover is off, look for the fluid level. It should be at the bottom of the clutch pack according to the picture in the manual. If the fluid is high enough to flow out of the cover, then it is too high and will effect the way the clutch engages. Remove the cover, adjust the clutch, and adjust the fluid level to a point at the bottom of the clutch pack, reinstall cover, go for a ride.
HDSG is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 09:03 AM   #8 (permalink)
bagga's Avatar
bagga wants to know Dino or Syn?
is you clutch working how you like it? if it is don't touch it.
bagga is online now   Reply With Quote Quick reply to this message
Old 09-14-2010, 10:17 AM   #9 (permalink)
bigbadal's Avatar
bigbadal wants to know Dino or Syn?
Very nice looking product. If I didn't have a lift already, I would seriously consider one of these for my bike.
bigbadal is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 01:58 PM   #10 (permalink)
Thanks for the input! The dealer installed a new clutch free of charge less than 1000 miles ago due to the metal disks being warped (couldn't find neutral) when I bought it.
After a road trip from Hattiesburg to Port St Joe, FL over Labor Day weekend, I have noticed that the friction zone has moved to the end of the lever travel, right before I let go of the lever. It used to be closer in the middle of the lever travel. Anyway, I figure it just needs adjusting.
David
Old 09-14-2010, 02:31 PM   #11 (permalink)
cracker III wants to know Dino or Syn?
set the kick stand on a 2 x 4 it will be level enough not to spill any oil.
cracker III is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 08:39 PM   #12 (permalink)
The great camel toe escap
1fast2liter's Avatar
1fast2liter wants to know Dino or Syn?
wich way do you turn the screw to lightly seat it to adjust it... ive put on 20,000 and havent adjusted it yet.. noticed yesturday that taking off in first it seems to shudder almost like a new clutch. no shuddering at any other speeds or engaugment
14" bagger apes
99 flhtc 103"
44mm sc carb kit
sc intake kit
vance and hinse ho pro pipe 2-1
103+ heads p&p by hoban
with matching pistons
s&s 585 gear drives
sc pro stroker flywheel
tc88 adj ignition
estimated at 135hp/135tq
1fast2liter is offline   Reply With Quote Quick reply to this message
Old 09-14-2010, 09:18 PM   #13 (permalink)
It is a little more involved than just turning the adjuster to remove the free play.
1. Find the adjuster in the cable, front of motor alog frame down tubes.
2. Screw the fitting together to create play in the clutch lever.
3. Remove derby cover and break lock nut lose on center of clutch.
4. Adjust the center adjuster out to put a free plat in the adjuster.
5. Withe the lock nut backed off, turn the center adjuster in by hand until it just contacts the clutch, you will feel the play or gap go away.
6. Hold the center adjuster and tighten the lock nut, making sure you do not turn the center adjuster as you do so.
7. Go back to the cable adjuster and adjust about a strong 1/8 play between the lever and the stop as you squeese the lever and then tighten the lock nut on the cable adjuster. Slide the rubber boot back.
Hope this helps.
If the fluid is too high in the Primary it will effect how the clutch grabs. Should be at the bottom of the clutch, no higher.
Old 09-15-2010, 12:12 AM   #14 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
It won't spill. But I do suggest getting a lift.
I don't do all my maintanence at the same time. I may change fluid one night, do something the other, and something else another.
berserker is offline   Reply With Quote Quick reply to this message
Old 09-16-2010, 01:07 AM   #15 (permalink)
shouldnt i got about 28 oz r so in their... i think i fill with bike straight up... it just started doining it so i think i need to adjust .. thank you for the tips.
14" bagger apes
99 flhtc 103"
44mm sc carb kit
sc intake kit
s&s 585 gear drives
tc88 adj ignition
