primary oil question - Page 2 : V-Twin Forum: Harley Davidson Forums
Old 11-17-2012, 05:12 PM   #16 (permalink)
RG50 is on a distinguished road
Wow,you dug up an old one.Since then I bought a new bike!
Anyway,I use a Ratio-Rite measuring cup.Easy to pour the fluid in the little space.
These are great for mixing ratio's and measuring also.Been using one for ever.
Heres a link....
Amazon Amazon
2011 Electra Glide Limited
RG50 is offline   Reply With Quote
Old 11-18-2012, 01:36 AM   #17 (permalink)
gusotto is on a distinguished road
Originally Posted by Boston Tom View Post
Okay, I give up. What's the trick on getting the fresh oil into the primary drive? A funnel wasn't going to cut it, no way. There just isn't room next to the clutch once the derby cover is off. I ended up grabbing Pretty Wife's turkey baster and trickling it in there. Took a long time but I got er done. How do you guys do it?
I'll check back later for answers. Right now I gotta head to the kitchen aids department to make a purchase for somebody....
Some use a piece of cardboard.
Harley has a handy-dandy funnel that is for the primary.
Reasonable and can be used over and over.
gusotto is offline   Reply With Quote
Old 11-18-2012, 10:58 AM   #18 (permalink)
RogerDodger is on a distinguished road
First, you're new here so here's a welcome to you.
Second, find a funnel with a small enough spout to fit - I have one so I know they are available.
Third, if you have a question do not be afraid to start a new thread. Readers will not have to sort through the many old dead posts just to get to your actual question.
RogerDodger is offline   Reply With Quote
Old 11-18-2012, 01:52 PM   #19 (permalink)
Mike02's Avatar
Mike02 is on a distinguished road
HD actually sells the perfect funnel that works just for this....another option that will work in a pinch is a paper plate cut and bent upwards...
Mike02 is offline   Reply With Quote
Old 11-23-2012, 05:16 PM   #20 (permalink)
btsom is on a distinguished road
The long funnel designed for the dipstick tube on automatic transmissions works well also. Not very expensive from Oreilly's, Autozone, Walmart etc.
btsom is offline   Reply With Quote
Old 12-01-2012, 09:54 PM   #21 (permalink)
BUBBIE is on a distinguished road
Secret...
Usa a piece of cardboard, the same kind i use under the oil filter to carry out the oil...
Derby cover off..... Use a 3" wide by 6" long cardboard will make a good pour surface....
You'll figure out HOW, Lots of ways to fashion it to work...
signed....BUBBIE
BUBBIE is offline   Reply With Quote
Old 12-02-2012, 09:43 AM   #22 (permalink)
Dipstick's Avatar
Dipstick is on a distinguished road
I have this funnel that I can bend to fit just about anything.
www.formafunnel.com
Some dealership have them. If yours doesn't try an auto parts store. About $20
02 Road King
PC III
48mm polished throttle body
Hooker slip-on
Fullsac true duel conversion
SE 203 cams
Baisley oil spring
95 inch
Dipstick is online now   Reply With Quote
Old 12-13-2012, 04:29 AM   #23 (permalink)
mariner227 is on a distinguished road
+1. I use the same method. Never spill a drop!
2010 Ultra, HQ107st, SE AC, TTS, Fuelmotto 2 into 1 into 2 headpipe with Jackpot Dyno tuned slipons- slash up, Sundowner, built by Guy Dalton, tuned by Doc.
mariner227 is offline   Reply With Quote
Old 12-13-2012, 05:03 PM   #24 (permalink)
07 STREETGLIDE's Avatar
07 STREETGLIDE is on a distinguished road
HD sells a funnel for the primary $5.95 works like a champ!
07 SG,Black Cherry Pearl, Stage 1,Thunder 2 into 1 Header, K&N, Sert, H.D. Passing Lights, HID,Run/Stop/Turn With LED Bulbs,Led Ground Effects Brake Light,Passenger Back Rest,Amsoil in Big Hole,Redline V-twin shockproof trans,Redline V-twin primary fluid. "O" so smooth [B]"Gone on a Slowride taking in the views"
07 STREETGLIDE is offline   Reply With Quote
