2010 O2 Sensor Routing Question : V-Twin Forum: Harley Davidson Forums
Old 05-07-2010, 06:06 PM   #1 (permalink)
Sniper
gunnysgt's Avatar
gunnysgt wants to know Dino or Syn?
Has anyone with the new sensors pulled the wires to change pipes? I was familiar with the earlier routing location to the plugs, it was easy. Where are the plugs on the 2010's? I followed the wires up along the frame then they disappear. Are the plugs beneath the ECM under the seat or what?? Gonna order some new pipes and wanted to be ready. My service manual is an 08 and good for most stuff but not this.
Riding Harley #35, keep'em comin'
gunnysgt is offline   Reply With Quote Quick reply to this message
Old 05-07-2010, 07:11 PM   #2 (permalink)
Moneygreen
arealinvestor's Avatar
I had a 07-08 Boarzilla retro fitted for my 2010 Ultra.Dave had to tap pipe & relocate the oxygen sensors.It came out great.The oxygen sensors go into the pipe near the tranny!!!
T-Man gear crank set
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 05-07-2010, 09:03 PM   #3 (permalink)
Sniper
gunnysgt's Avatar
yea I know where they fit in to the pipe at the header. The O2 sensors are easily visible. I followed the wires from there to the frame near the swing arm, what I don't know is where the wires go from there to finish out as plugs into the ECM
Old 05-08-2010, 05:41 AM   #4 (permalink)
msocko3's Avatar
Their under the right side cover, one is black and the other is light gray.
2012 GL1800 Hannigan.
Old 05-08-2010, 06:03 AM   #5 (permalink)
Sniper
gunnysgt's Avatar
Thanks, I'll pull that cover off today and check it out. The 09 and earlier sensor wires were pretty easy to deal with, the junction plugs were easy to find. I was hoping they weren't buried under the seat in that mass of wire looms there.
Old 05-08-2010, 05:14 PM   #6 (permalink)
msocko3's Avatar
Once you pull the side cover you'll see them with no problems, the connector is different than 07 - 09.
Old 05-11-2010, 10:10 AM   #7 (permalink)
Doof! There it is.....
'05Train's Avatar
'05Train wants to know Dino or Syn?
Hey Gunny, I cheated and didn't bother pulling the connectors. Just be careful you don't bind them up too badly when you take them off, then twist them the opposite direction before you screw them back in.
'05 Vivid Black Night Train
Lots o' black
103 by Dave at JD's
116.70/116.01 SAE
'10 Scarlet Red/Vivid Black Electra Glide Ultra Limited
Stage 1, Intiminators, 575s
'05Train is offline   Reply With Quote Quick reply to this message
