Harley 2 into 1 into 2 : V-Twin Forum: Harley Davidson Forums
Old 04-29-2010, 09:11 PM   #1 (permalink)
head's Avatar
head wants to know Dino or Syn?
will the factory 2 into 1 into 2 exhaust sytems on the new bikes retrofit to the older models such as my 2006 flhri?
head
head is offline   Reply With Quote Quick reply to this message
Old 04-29-2010, 09:45 PM   #2 (permalink)
aka_Matt wants to know Dino or Syn?
no......... been asked plenty of times
Matt
FOR SALE
aka_Matt is offline   Reply With Quote Quick reply to this message
Old 04-29-2010, 10:27 PM   #3 (permalink)
head's Avatar
thanks for the quick answer. figured that it might be different due to the frame changes. oh well....
head
Old 04-30-2010, 05:31 AM   #4 (permalink)
eglider05 wants to know Dino or Syn?
head
Yes it can and has been done. It requires an oil pan from an 09 later and the transmission has to be drilled and tapped for a hangar. I'm currently in the process of collecting the parts to do it on my 05.
Rick
eglider05 is offline   Reply With Quote Quick reply to this message
Old 04-30-2010, 09:10 AM   #5 (permalink)
head's Avatar
i knew that somebody must have been able to make one work. dont know that i wanna switch oil pans though just for an exhaust system. not knocking it though by any means.
before i bought my twin cam, local goodwill had a complete takeoff system from a new bike for 35 bucks including slip on mufflers but excluding heat shields...should coulda woulda....
head
Old 04-30-2010, 06:34 PM   #6 (permalink)
head
I don't have a problem with the oil pan swap but I may have run into another snag. I have a bagger Brace that may be in the way and I'm not willing to give it up. I found a source for the 09 pipes I need but I have to wait for someone who has already done this to get back to me with some measurements before I proceed.
Rick
Old 05-01-2010, 10:28 AM   #7 (permalink)
zigtems wants to know Dino or Syn?
The 2010 2 into 1 on the road glide and street glide WILL fit. I have one on my 2003 flhtci. Had to slightly modify the bracket at the tranny, same slip on muffler that wqas on stock.
zigtems is offline   Reply With Quote Quick reply to this message
Old 05-01-2010, 01:51 PM   #8 (permalink)
head's Avatar
now we're getting somewhere..
no oil pan change huh? did you notice any difference in performance with the same slip on mufflers?
head
Old 05-01-2010, 02:15 PM   #9 (permalink)
No change to oil pan. This is the 2 into 1 on the 2010 road and street glide, not the 2 into 1 into 2 on the classics and ultra classics. . I put this on with the a big bore kit, p and p heads, ect. The final numbers were 97 torque and 88 horse. 42 mpg highway. I intend to put a rinehart slip on when coins are available. Rinehart just can out with a slip on for 2010 2 into 1 exhaust. I also have a 6 speed to drop in.
Old 05-02-2010, 06:12 AM   #10 (permalink)
The oil pan change is required with the 2-1-2 header pipe due to the cross under pipe.
Rick
Old 07-11-2010, 08:19 PM   #11 (permalink)
Rick
Update, I knew the stock 09 2-1-2 exhaust would work on my 05 with some mods but apparently no one had yet tried one of the aftermarket 2-1-2 head pipes such as the Fullsac, Jackpot or V&H Power Duals.
I decided to be a guniea pig and ordered a V&H head pipe. With the oil pan swap, 2 holes drilled in the back of the tranny and slotting the holes on the supplied tranny side mount it worked out great and I am extremely happy with how it turned out.
Rick
Old 07-13-2010, 11:27 AM   #12 (permalink)
bdejong11129 wants to know Dino or Syn?
aka_Matt, No disrespect meant, but this is why its sometimes good to ask the same question. Times change and there's always someone out there attempting to do the impossible.
eglider05 - That looks pretty cool, how about some pictures and a parts lists for the rest of us contemplating this change?
bdejong11129 is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 04:57 PM   #13 (permalink)
The great camel toe escap
1fast2liter's Avatar
1fast2liter wants to know Dino or Syn?
wonder what the gain would be torun it other then fooling people into thinking you have a new bike.... lookes nice though
14" bagger apes
99 flhtc 103"
44mm sc carb kit
sc intake kit
vance and hinse ho pro pipe 2-1
103+ heads p&p by hoban
with matching pistons
s&s 585 gear drives
sc pro stroker flywheel
Crane hi4
1fast2liter is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 05:17 PM   #14 (permalink)
head's Avatar
well,i like them because to me they could acomplish two things. you would have the performance of the 2 into 1 but still have two dual exhausts coming out the rear of the bagger,which i think just looks right.
head
Old 07-14-2010, 09:32 AM   #15 (permalink)
LE PEW's Avatar
LE PEW wants to know Dino or Syn?
Only one way to tell for sure, dyno before and after with no changes other than exhaust. You might be surprised how well stock exhuast works with engine combos.
Just sayin .......
My gallery
http://www.v-twinforum.com/gallery/data/500/thumbs/scan.jpg
LE PEW is offline   Reply With Quote Quick reply to this message
