07 Ultra Classic stalls : V-Twin Forum: Harley Davidson Forums
Old 04-03-2010, 07:19 PM   #1 (permalink)
rehorner wants to know Dino or Syn?
I have a 2007 Ultra Classic and every once in awhile it will shut down when coming to a stop. I can put in neutral and it starts right back up and takes off with no problem. This is an intermiten problem. It happened for the first time last year, 3 times. It just happened again last week, 3 stops in a row. It does'nt miss or back fire, it just cuts off. Any one have this problem? Please HELP!
rehorner is offline   Reply With Quote Quick reply to this message
Old 04-03-2010, 07:47 PM   #2 (permalink)
46u
46u's Avatar
46u wants to know where he is and how he got here
Are you getting a history code?
6 more states and I will have them all on one motorcycle
If you see my motorcycle on a trailer call the police it was stolen!
46u is offline   Reply With Quote Quick reply to this message
Old 04-03-2010, 08:02 PM   #3 (permalink)
maddogg4's Avatar
maddogg4 wants to know Dino or Syn?
Seems to be a common occurrence in '07's. The idle control unit is acting up due to some debris or dirt in the pintle hole. Happens especially when conditions are wet or real humid down here. Take off the air cleaner and look in the intake. There is a hole at 12 o'clock. Twist the throttle and you will notice it opening and closing. Clean it out with some fuel injection/linkage cleaner until the spray is clear. Should take care of the problem.
When the game is over, the King and Pawn go back in the same box.
maddogg4 is offline   Reply With Quote Quick reply to this message
Old 04-03-2010, 08:06 PM   #4 (permalink)
LoneEagle964's Avatar
LoneEagle964 wants to know Dino or Syn?
you can check this post http://www.v-twinforum.com/forums/tw...utch-idle.html
it discusses about the same thing and tells how to clean the IAC
LoneEagle
LoneEagle964 is offline   Reply With Quote Quick reply to this message
Old 04-06-2010, 09:07 PM   #5 (permalink)
Thanks for the help. It's more than I got from my dealership. I'll let you's know how it goes.
Old 04-06-2010, 09:33 PM   #6 (permalink)
top-asmc's Avatar
top-asmc wants to know Dino or Syn?
don't forget it could also be a loose battery cable as well.
I did the IAC thing and it didn't solve my problem though it did clear up a rough idle.
It seems my negative cable was just loose enough that the inertia of slowing down broke the connection just enough for the bike to cut off.
Tightened the cable and it hasn't happened again.
"Alcohol is my way of life, And I aim to keep it.
Homer Simpson
top-asmc is offline   Reply With Quote Quick reply to this message
