oil coolers anyone who is using one : V-Twin Forum: Harley Davidson Forums
Old 02-21-2010, 09:37 PM   #1 (permalink)
wydopn231 is on a distinguished road
Ive been thinking about installing oil cooler on my RKC.Since Inbored it out to 4.250(114 ci) it seems hotter.Yea i mean temp wise.I was hoping to hear from other running oil cooler.Whats the gifferance in temps.What brand.Looking at Jags system maybe the dual system.Also looking at canister style filter with finned outer,that claims to drop temp some.
So what you running and how good is it?
Only the stupid know to much to learn something new
wydopn231 is offline   Reply With Quote
Old 02-21-2010, 09:54 PM   #2 (permalink)
WFO
mtrhead269's Avatar
mtrhead269 is on a distinguished road
I run the jag horizontial mounts 10 row oil cooler. Ride in Northern Nevada/California.
107" 10.5/1 compression ride agressive mostly 1up.
Pre oil cooler rear cyl would come on in town. after a long run engine would be in 35-255 range depending on air temp
after cooler install get hot in traffic but cyl never kicks out after long sustained speed run temp is in 200-225 range.
mtrhead269 is offline   Reply With Quote
Old 02-21-2010, 10:58 PM   #3 (permalink)
HogBag is on a distinguished road
I have a jag 6 row deluxe vertical with manual thermostat on my 103 cube 07 flht . Australian summer was running at 275 before oil cooler install. Bike now runs 200 220 summer 170 180 winter. Don't mess with the auto thermostat get a manual or run a cover over the oil cooler in winter. I had a 10 row Harley (CHINA) cooler on my old 06 dyna with the auto thermostat somehow it jammed closed and would not let the oil through to the cooler. The Jagg filter housing runs both oil lines under the filter and is offset to miss the crank sensor. The harley (china) housing runs the oil lines above the oil filter with no offset for the crank sensor. Buy a USA made Jagg
Thats my experience with both units
HogBag is offline   Reply With Quote
Old 02-21-2010, 11:36 PM   #4 (permalink)
Just a kid at heart
wydeglyde's Avatar
wydeglyde is on a distinguished road
I run a 6 Row Jagg with Auto thermostat on my Roadglide. Haven't had a moments trouble in 4 years!
I ride year round and the auto thermo works! From what I've read the 10 row is probably the best on the market.
12 Road Glide Custom
wydeglyde is offline   Reply With Quote
Old 02-21-2010, 11:39 PM   #5 (permalink)
WFO
mtrhead269's Avatar
The Jagg is a well made unit. Easy co to deal with. easy install less than 45 minutes.
Old 02-21-2010, 11:51 PM   #6 (permalink)
Moneygreen
arealinvestor's Avatar
arealinvestor is an unknown quantity at this point
www.budsbikerparts.net
Budd makes a nice oil cooler too.Check there site out!!
Craig G.
BB & Baisley Hybrid Heads with man/Comp releases
Axtell Pistons & Cylinders set with high comp,Big CCP
Woods A/C kit & Lifters
T-Man gear crank set
Lenale cooling fan
Jagg 10 row oil cooler
K&P engineering oil filter
To much more to list!!!!!!
Old 02-22-2010, 12:31 AM   #7 (permalink)
LarryM is on a distinguished road
I run with the Harley cooler on my Ultra. When the bike is moving it seems to work.
However, when I'm stuck in the entrance of the Holland Tunnel or in the middle of the Tappan Zee Bridge with feet down the bike starts rockin' and rollin' when that rear cylinder shuts down due to overheating.
LarryM is offline   Reply With Quote
Old 02-22-2010, 07:09 AM   #8 (permalink)
Coolmaker's Avatar
Put fans in the back of it..
Old 02-22-2010, 07:47 AM   #9 (permalink)
Coupe55's Avatar
Coupe55 is on a distinguished road
Jagg 10 Row
2010 Harley Tri Glide, with the CAT it was running hot at idle in summer traffic conditions! Jagg Horizontal mount 10 Row with modified mount to make room for the Arizona Fan kit. Hooked to accessory switch and used the added female plug to run a Lanale Parade Fan. Kinda small, not much larger than horn cover it replaced! Colder Plug, will keep going down until it starts to soot and then go back up a heat number!
Richened up AFR at idle and some cat eating bacteria eat the Cat!
Amsoil synthetic but Mobile 1 or syn 3 should not flash off until over 300 degree's. Won't get a real test until July or August!
What if nothing really exist and life is just an illusion, then I definately paid to much for my Harley!
Hard work never killed anybody, but why take the chance!
Time is a great teacher but unfortunately it kills all its pupils!
On a Quantum Harley I don't know where I am but I'm going really fast!
I want to die peacfully in my sleep like grandpa did, not like the screaming passenger on his Harley!
Coupe55 is offline   Reply With Quote
Old 02-22-2010, 08:02 AM   #10 (permalink)
Shaw_2112's Avatar
Shaw_2112 is on a distinguished road
I have a Harley cooler, I can't tell you the exact temp difference but I can tell you it's a big one. I have a buddy with same year/make bike without the cooler and I can feel the difference between mine and his....
It may be that your only purpose in life was to serve as a bad example to others.....get over it....
https://sphotos.xx.fbcdn.net/hphotos-prn1/544741_439993552691766_1484245982_n.jpg
Shaw_2112 is offline   Reply With Quote
Old 02-22-2010, 08:09 AM   #11 (permalink)
nightrob's Avatar
I agree. I have the big sky fan kit behind my jagg 6 row low mount and i never hit over 240s evin in Japanese traffic.
2007 FXSTB
Friedrich Nietzsche
Old 02-22-2010, 08:49 AM   #12 (permalink)
FXDRYDR is on a distinguished road
Jagg 6-row on the down tube. Had it 4-5 yrs now. No thermostat to screw up. I use a cover when it's cold, take it off when it's warm. No probs.
Dunno how much it cools the motor. I got it for looks.
FXDRYDR
2003 FXD
124"
S&S stuff.
Baisley Pro Street heads
+ Level 2 Mojo.
Badass pipe.
Torq Monster Motorworks
spec'd & built, extra "Special Sauce."
TQ & HP TBD and really don't care.
Stay tuned.
FXDRYDR is offline   Reply With Quote
Old 02-22-2010, 10:00 AM   #13 (permalink)
rscalzo's Avatar
rscalzo is on a distinguished road
Beats being stuck IN the Holland (or Lincoln) tunnel. Maybe days years ago I'd ride into the city for lunch with my wife on the bike. Coming home at rush hour and sitting behind a Decamp bus spewing exhaust for an hour could not be healthy. I came out looking like a coal miner.
rscalzo is offline   Reply With Quote
Old 02-22-2010, 10:22 AM   #14 (permalink)
iclick's Avatar
iclick is on a distinguished road
I've had the HD Premium for three years with no problems. The standard thermostat works great and oil temps normally run 205° while moving >45mph in summer, never more than 230° (rarely) in traffic. In winter riding with temps in the 60's the oil temp is around 180°, up to 200° in traffic. I think all TC engines should be equipped with an oil cooler.
'07 Street Ultra ®
Fuel Moto Stage 1, Power Vision, SE255 cams
iclick is offline   Reply With Quote
Old 02-22-2010, 10:48 AM   #15 (permalink)
FMC01 is on a distinguished road
I Put A Jag 10 Row On My 07 Ultra And The Difference In Heat Given Off By The Motor Was Noticeable. My 08 Se Ultra Has One And Thats Not By Accident!
FMC01 is offline   Reply With Quote
