Accessory Wiring question : V-Twin Forum: Harley Davidson Forums
Old 11-28-2009, 02:12 PM   #1 (permalink)
dhornick's Avatar
dhornick wants to know Dino or Syn?
Accessory Wiring question......
How do I hardwire something into a accessory switch in the dash of a FLHX using one of the factory switch locations in the dash panel? I have ordered a GPS mount and will need to hardwire it in. On my Dyna I always just plugged it into my battery tender plug but will want this one more permanent.
"Roll, roll me away,
Im gonna roll me away tonight
Gotta keep rollin, gotta keep ridin,
Keep searchin till I find whats right"
13 FLHTK Ultra Classic Limited - Current
07 FLHX Street Glide Vivid Black - Sold
08 FLHRC Road King Classic Pearl White / Black - Sold
07 XL1200L Sportster - Sold
04 FXDWG Wide Glide - Sold
IBA Certified #42315
SS1000
BB1500
dhornick is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 10:17 AM   #2 (permalink)
dklanecky's Avatar
dklanecky wants to know Dino or Syn?
I believe the connector for the accessory switch on the dash is located under your seat, at least it is on the RG.
73 Sporty - Sold
07 Sporty - Sold
09 Vivid Black Road Glide (FLTR) with ABS, Security, Fuelmoto Satge One, Clearview, Harley Hammock Seat, Hogg Chopps Lowers, Bright Ass Tail Light, SERG Headlight Bezel, Cruising Southeasten Wisconsin, Delivered 3/6/2009
09 Black Fat Bob (FXDF) in Vivid Black of course, Mustang Solo, Screaming Eagle Intake, PCV, Big City Thunder "Baffles", Delivered 5/1/2009
dklanecky is offline   Reply With Quote Quick reply to this message
Old 11-29-2009, 01:45 PM   #3 (permalink)
cata5803's Avatar
cata5803 wants to know Dino or Syn?
Just an Idea, you could tie it in with the cigg lighter. Take outer fairing off and it't right there. I put a set of passing lamps on a FLHX and the instructions were go in the wire harness which I did. Just thought about what I mentioned, Hope it helps...
cata5803 is offline   Reply With Quote Quick reply to this message
Old 11-30-2009, 08:37 AM   #4 (permalink)
dhornick's Avatar
Bump
I'd like more input from those who might not have seen the posted question please. Electrical doings are the thing I know the least about and don’t really trust myself and I need all the help I can get on this one…..
SS1000
BB1500
Old 11-30-2009, 09:57 PM   #5 (permalink)
top-asmc's Avatar
top-asmc wants to know Dino or Syn?
The acc. switch controls an emty plug under the seat. If you want to avoid having to run wires under the tank back to that area you can as someone mentioned tap into the cig lighter circuit.
I have mounted both the MP3player and the Radar detector and the instructions from HD said to tap them both into the front fender light circuit.
So it really depends on how much amperge the item draws and wether or not you want it to come on with the key or prefer to control it with the switch.
"Alcohol is my way of life, And I aim to keep it.
Homer Simpson
top-asmc is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 02:25 PM   #6 (permalink)
cata5803's Avatar
Any Luck with the accessory switch ??
Old 12-02-2009, 03:21 PM   #7 (permalink)
berserker's Avatar
berserker is still riding a stock bike berserker is still riding a stock bike berserker is still riding a stock bike
alot of people just plug them into the cigerette lighter. Then you can just unplug, when you don't want it sitting on the bike, and getting stolen. But I do like the idea of wiring to the back side of the cigerette lighter if you want it cleaner looking.
berserker is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 04:17 PM   #8 (permalink)
Born2Ride's Avatar
Born2Ride wants to know Dino or Syn?
Namz makes a nice little plug that plugs in under the seat and gives you a power/ground source for wiring such things.Maybe that will help.In fact you could give them a call and they can give you the best advice.They make plugs,kits,harnesses,etc for our bikes..........
2009 Black Street Glide
26'' chrome Sinister wheel
Chrome HHI lower legs/single rotor
Frame raked 7*/stretched 1"
HHI 6 piston caliper
HHI 9* raked trees
Arnott air ride
Boomcan slip-ons
C&C seat
Wild1 577 handlebars
Banana boards
LED tail/turns
PYO dash
Sinister windsheild
Stretched bags
Stretched Fender
Stretched Side panels
Born2Ride is offline   Reply With Quote Quick reply to this message
Old 12-02-2009, 05:05 PM   #9 (permalink)
dhornick's Avatar
OK checkin them out now. If they dont work out the next best thing is the cig lighter looks like to me.
Thanks everyone.
SS1000
BB1500
Old 12-03-2009, 06:04 PM   #10 (permalink)
rscalzo's Avatar
rscalzo wants to know Dino or Syn?
Inserting the cigarette lighter plug into the outlet will not work. Turning the bars will cause the plug to smack into the tank possibly causing a dent. I managed to find a right angle 12 volt plug made especially for that purpose. I had to wire it myself but it works. (I use it for a heated jacket linber).
The best way to go if you intend on using the cigarette lighter plug is to convert it to this syle outlet. http://www.powerletproducts.com/prod...etal-adapter/1
It can be done without removing anything. Then you can buy any type connector in the 90 degree style and use it without fear of hitting the tank.
http://www.powerletproducts.com/shop...-cables/PWRCBL
rscalzo is offline   Reply With Quote Quick reply to this message
Old 12-04-2009, 10:18 AM   #11 (permalink)
davjour's Avatar
davjour wants to know Dino or Syn?
I mounted an accesory plug on the right side of my fairing. Approx the same position the cig lighter is on the left side. I cut off the connector and wired it into the head light wiring harness. There is a plastic red cap on the harness, take off the cap and use that one. They say do not use acc in your cig lighter. Alot of plugs will distort the cig lighter hole. My gps worked fine in my cig lighter but my portable xm radio distorted the hole and my cig lighter wouldn't stay in after that.
davjour is offline   Reply With Quote Quick reply to this message
Old 12-13-2009, 05:16 PM   #12 (permalink)
JR75 wants to know Dino or Syn?
Under your seat is the plug controlled by the accessory switch. For about eight bucks your dealer can order the parts to build the male plug onto your GPS wires to plug into the female outlet plug. OR, remove your outer fairing and on either side of your headlight are two redish colored plastic covers which will plug right up to your GPS or at least this was so on my '08 Ultra. My GPS is hooked there under the fairing and my heated jacket liner & gloves are hooked under the seat to the accessory outlet. Hope that helps from the old man.
JR75 is offline   Reply With Quote Quick reply to this message
Old 12-14-2009, 12:00 PM   #13 (permalink)
dhornick's Avatar
I truly appreciate your post but its way too generic for me. I need specifics like when you say “Under your seat is the plug controlled by the accessory switch”. The problem is that there are a ton of things under my seat and I have no idea what plug you’re writing about or what it would even look like. And as far as taking off my outer faring, since I just got the bike I have no idea how to or how hard it would be to take off to be able to get to the other two redish colored plastic covered plugs you speak of.
SS1000
BB1500
Old 12-15-2009, 09:27 AM   #14 (permalink)
dklanecky's Avatar
How about buying your bike a couple of Christmas presents, the parts manual (09 numbers are 99456-09A and the service manual 99483-09). Not sure about your 07 numbers.
The combination is really all you'll need to do 90% of the stuff talked about on these forums.
I use mine a lot, and while the service manual is mandatory, the parts book is just as important to me as the visual drawings of all the parts assemblies are excellent.
73 Sporty - Sold
07 Sporty - Sold
Old 12-15-2009, 10:29 AM   #15 (permalink)
dhornick's Avatar
Agreed, they are essential. I do already have the Service Manual but still need to secure the Parts manual. Problem is that I learn from doing. Never been able to learn from reading a book. Ugh!
SS1000
BB1500
