06 streetglide intermittent starting problem
have this starting problem driving me nuts, it started wednesday , in the am bike would not start, motor would turn over, just not very fast, on friday started right up, that night did it again, turned over real slow, no start,, saturday started, several times in a row, on sunday no start, swapped battery out, started, road all day was fine, that evening did it again, was at a bar, was able to push start it, couple hours later started right up, today still started, took some readings:
checked volts at battery 12.82
with ignition switch on 12.30 volts
starting it drops to 10.69
running 14.25 volts
starter is engaging as it turns the motor, just real slow when it doesnt start.
ignition I would think is good since it started fine where push starting it.
same problem with 2 different batterys.
