Harley Amp 97
I picked up a 97 Tour pak. It has an Amp attached to the bottom. 1 end has a circle plug 7 holes. The other end is rectangle with an orange end 12 holes? It is P/N 76192-94B It says 20w X 2 motorcycle power amp. Does anyone know what wire go where. A wiring diagram to tell me what wire does what? The pak came with speakers but their connection are a 2 wire plug? I have no problem cutting the connections off if need be. If I know the wire code I can at least test it to see if it works then go from there. Thanks for any help
